Tractor comparisons (MF, Kubota, Kioti)
   / Tractor comparisons (MF, Kubota, Kioti) #11
You can add weight to any tractor and make it a "heavy" utility. Heck between iron weights and fluids you can add a good 1500lbs to the tires alone.
If you are concerned about COG New Holland makes low profile TN's that would probably be along the lines of what your looking for.
   / Tractor comparisons (MF, Kubota, Kioti) #12
<font color="blue"> You can add weight to any tractor and make it a "heavy" utility </font>
You are missing the point and I think that you know that you are. By a heavy utility, I am not referring to only the total weigh even though that is a big part. The other part being, the size of the components. The lift arms, the axles, the transmission case. Everything is heavier. As much as some would like to think that Kubota tractors are heavy duty, they are not. Everything that they have is compacts, even though they may be listed and horsepowered as utilities.
   / Tractor comparisons (MF, Kubota, Kioti) #13
<font color="blue"> As much as some would like to think that Kubota tractors are heavy duty, they are not. </font>
/forums/images/graemlins/blush.gif /forums/images/graemlins/shocked.gif
RedDog
   / Tractor comparisons (MF, Kubota, Kioti) #14
I understand your point, that Kubotas are engineered with "lighter" components than some other tractors, but Messick's point is totally valid: If weight on the ground is the important factor in performance of a task then it matters not whether the weight comes from the cast iron axle or the beet juice in the tires. If you are suggesting that Kubotas are lightweight with the implication that they are less sturdy I would like to see some data. I think the conventional wisdom and experience on TBN suggests that they are as tough and reliable as anything out there. Lightweight in no way implies weak so long as products are properly engineered and built.
   / Tractor comparisons (MF, Kubota, Kioti) #15
<font color="blue"> I would like to see some data. </font>
For what? Go look at them. It is self appearant.
<font color="blue"> If you are suggesting that Kubotas are lightweight with the implication that they are less sturdy I would like to see some data. </font>
Once again. Go look at them.
I knew that someone would try to say that I was cutting down Kubota. I am not. That are a good or very good tractor for many things. Every manufacture can't have an exact cross over model for every other manufacture. Kubota has had their name in light weight tractors. That is where they shine. They just don't have a heavy duty utility nor do they have two hundred horse tractors.
<font color="blue">Lightweight in no way implies weak so long as products are properly engineered and built. </font>
Light weight or light duty doesn't mean bad quality.
   / Tractor comparisons (MF, Kubota, Kioti) #16
Well, if it matters I have never heard of a single person who has broken a transmission case, 3pt hardware, axle, or the like on any of the utility class machines. No one will argue that Kubota builds a light weight tractor, however to imply that its a light duty machine is simply wrong. I'm not quite sure what your looking for? If another machine is "heavier" great, it just seems to me that all the extra mass is rather pointless. I'd rather be able to choose where I want my weight and how much of it I need.
</font><font color="blue" class="small">( Light weight or light duty doesn't mean bad quality.
)</font>
Then what are you trying to say?
   / Tractor comparisons (MF, Kubota, Kioti) #17
Fellows,
You can put all the weight on a tractor that you want, but that doesn't make it heavy duty or light duty. All that means is that you weighted it down.
   / Tractor comparisons (MF, Kubota, Kioti) #18
I also want to say that I have a MF 40 horse compact. It is in the same class as the Kubotas. It many be heavy duty when compared to some compacts, but it is not in the same duty class as a 400 series Massey. No way, No how.
   / Tractor comparisons (MF, Kubota, Kioti) #19
Yeah,
Everyone is right to an extent. Just to make sure I went and checked the specs between the M6800 and MF471...the 471 specs out better, weighs more, etc. I have seen both units and the MF is obviously the stouter looking...now I would rather have the Kubota because it is much more refined and the hydraulic shuttle is nice...just my thoughts.
   / Tractor comparisons (MF, Kubota, Kioti) #20
You are right. They each have their place and the 400s don't have all the bells and whisles.
2012 Ford F-550 Enclosed Service Truck (A55788)
2012 Ford F-550...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2006 Big Tow BE-5BL (A47477)
2006 Big Tow...
1983 Case 580D (A47477)
1983 Case 580D...
2016 Ford Escape SUV (A55758)
2016 Ford Escape...
