Tractor dirt/snow blade - homemade
   / Tractor dirt/snow blade - homemade #31
Awesome work!
   / Tractor dirt/snow blade - homemade #32
Please share you secret for keeping everything aligned!
If I would weld this everything would be warped and misaligned.
Looks good!
Sent from my iPhone 5s 64Gb using TractorByNet
Exactly what I thought.
Only explanation I can offer is that his fit up is so good that there's no gaps to close up during welding to cause distortion.
That and real good heat management.
Great looking work!
Any idea what it will weigh when you're all done?
   / Tractor dirt/snow blade - homemade #33
Exactly what I thought. Only explanation I can offer is that his fit up is so good that there's no gaps to close up during welding to cause distortion. That and real good heat management. Great looking work! Any idea what it will weigh when you're all done?
fit up is one thing that will help as is clamping but many of those welds are continuous meaning stitch welding on alternating sides was probably not used.
Clamping will only get you so far-then again maybe I'm not clamping properly and allowing to cool?
Maybe SA could enlighten us as well as BFreaky.
It's actually very simple. I learned it over the years. First and most important is the precision of each individual part. Next comes proper clamping and tack welding. After that I make continuous welds on oposite sides of one piece. That heats up the part equaly. Both welds tend to "pull" the part. This way they pull each other and are actually pulling the part in balance
   / Tractor dirt/snow blade - homemade #35
I will take your word for it as it obviously works for you!
I will need to pay more attention to fit up and tacking/sequence of welds in the future.
Thanks for the explanation
   / Tractor dirt/snow blade - homemade #36
Can you describe "weld opposite sides of one piece"? Do you mean small sections back and forth to keep the heat balanced? How long of a weld and how thick of metal?
   / Tractor dirt/snow blade - homemade #37
Yes, that's how you should be doing it to keep it from warping or lifting. Opposite sides, opposite corners, then fill in between as needed once the piece can't shift on you. I usually do half an inch at a time myself, until all the sides and corners are attached and I can fill in the rest for strength if needed. Or at least tack weld every inch or so to hold it down before going crazy with the heavy welds for strength. But then, I don't have a lot of clamps so it has to get held together before I really weld the parts. :D
Exactly. The idea is to minimize bending and lifting of parts you weld.
Anyway...I'm back on track after all these holidays so I finished trip mechanism and got 2 largest parts together.
Next come cylinders and skid shoes. After that lots of grinding, cleanup and paint
   / Tractor dirt/snow blade - homemade #39
Exactly. The idea is to minimize bending and lifting of parts you weld. Anyway...I'm back on track after all these holidays so I finished trip mechanism and got 2 largest parts together. Next come cylinders and skid shoes. After that lots of grinding, cleanup and paint
Awesome! How much do you think it will weight when done?
Approx. 400 kg
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
40' CONTAINER (A51244)
SHOP BUILT 96" X 25' TRI AXLE GOOSENECK TRAILER (A51247)
SHOP BUILT 96" X...
2014 FREIGHTLINER BUSINESS CLASS M2 SERVICE TRUCK (A51247)
2014 FREIGHTLINER...
