flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,555
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
MossRoad said:The discussion is pulling something with a tractor and using a 3pt implement as a wheelie bar instead of attaching the chain to the proper point lower than the centerline of the rear axle.
3pt hitches do not have "power down". If they did, we could raise the rear end of the tractor up off the ground by lowering the 3pt hitch. There is nothing holding the implement down but gravity. Yes, there is a maximum upward travel to the 3 pt arms. However, that travel is much farther than most of us realize. Let's try it.
Hook up a box blade to a 3pt hitch. Back up to an unmovable stump. Drop the box blade to within one inch of the ground. Hook a chain to the stump and run it over or under the box blade. Doesn't matter. Hook it to a point on the rear of the tractor higher than the centerline of the axle. Rev up the tractor and take off. As soon as the chain tightens and the tires grip, the front of the tractor will launch skyward because there is nothing holding the box blade down. The tractor will rotate until the maximum travel of the 3pt arms is reached. My guess is the tractor will be at an angle greater than 45 degrees in less that 1/2 second. I base this on what I have read on several reports on tractor roll overs and most agree that it only takes 3/4 of a second to go completely vertical. At that point, most operators will be in "poop your pants" mode. Not many folks (myself included) would have the skills to quickly react properly at that angle. Maybe the implement will keep it from going over the rest of the way. Maybe the top link will snap or bend and over you go.
The point is, pulling should be done by attaching to the proper place below the centerline of the rear axle always. No exceptions. If we hook up properly, we won't need wheelie bars.
OK, let's say I get my 1966 MF-135 diesel out of the garage and hook my 6-ft wide offset drag disk to the swinging drawbar. What are the risks with this hookup of a flip over should the disc become stuck due to a rock, root or other piece of buried junk? Is the drawbar hookup completely reliable so a flip over cannot happen? BTW: regardless of the answer, I plan to get a ROPS installed on the 135 before trying any of this heavy duty ground engagement work with that tractor.
When I hook a double bottom plow to the MF-135 3pt and operate in draft mode, same question if the plow gets stuck: what are the chances of a flip over in this case?
