Tractor Forks
   / Tractor Forks #11
If you get a long enough bolt, there is a pretty good unthreaded section on it. They only tend to thread the area likely to have the nut on it, leaving the rest full diameter, at least around here. A 6 inch bolt will probably have 4 1/2 or 5 inches of unthreaded length just below the head. Measure the amount you need unthreaded and go shopping.
   / Tractor Forks
The top links are different diameter. Cat. 1 is 3/4" dia. & if you go up to a Cat. 2 top link pin it jumps up to 1" dia. I need 7/8" diameter for lower link arms.
Going to try New Holland Dealership this morning. I am now trying to also source 1.25" dia. pins for FEL so I can try out forks on front.
Thanks for the link. If New Holland does'nt have anything I will try there next. They may have something close to what I need.
Vic
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
LOT: Globel Industrial 44" Portable Evaporative Cooler, 24" Electric Pedestal Fan (A59076)
LOT: Globel...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
