tractor hauling
   / tractor hauling #21
I have hooks welded to my bucket, and use 1 High test 5/16 chain on the front but hooking to the trailer then to the hook, then throw the chain to the other side and repeat. Then at the back, I have a clevis on the draw bar and run a 3/8 high test chain through it and use a standard binder with a 2 ft pipe to cinch it down. This setup works great, and is safe and quick. When I load up tonight, I'll try to take a few pics to give you a clear visual.
Does anyone use the ratcheting type binders? I bought one to try but don't care for it as much.
   / tractor hauling #22
<font color="blue"> Overkill or not, I do know for a fact that here in Pa. it is the Law that 1 chain is required for each corner of every machine.
Also every boom that can swing must be locked with a pin and/or chained to prevent swing. </font>
This is the way, I understand the new law that went into effect as of January 1, 2004. This is a U S Department of Transportation law for all states.
   / tractor hauling #23
I think you would want ratchet straps rated for 3X your load. As for chafing.. I use old fire hose as a sleave for my straps.
Soundguy
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
2020 Case 5550 Trident (A56435)
2020 Case 5550...
2015 Yale 5K Forklift (A56435)
2015 Yale 5K...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
