Tractor Hydraulic Fluid Data Page
   / Tractor Hydraulic Fluid Data Page #1
john_bud
Super Member
   / Tractor Hydraulic Fluid Data Page #2
In case your interested I just found a tractor Hydraulic oil who's speccs actually say it is to be used in place of Super UDT. It is Chevron Synthetic All Weather THF. This is the only oil to my knowledge to say Super UDT on the label.
FYI
Greg H
   / Tractor Hydraulic Fluid Data Page #3
Chevron Synthetic Hydraulic Fluid for Farm/Tractor Use:
Chevron Synthetic All-Weather THF
Chevron All-Weather THF is a truly unique, high quality, multifunctional fluid, specially formulated for use in transmissions, final drives, wet brakes, and hydraulic systems of tractors and other equipment employing a common fluid reservoir.
Chevron All-Weather THF is specially designed for unsurpassed operation in all types of weather - both severe winter cold and extreme summer heat. In fact, Chevron All-Weather THF meets the requirements of both John Deere J20C and J20D specifications. This, combined with excellent oxidation stability, eliminates the need for seasonal oil changes.
Its distinctive orange color provides for easy product identification and leak detection.
· Chevron Synthetic All-Weather THF is recommended for use
· as a multifunctional and multiseasonal fluid in all types of tractors and construction equipment.
· in any application which calls for the following OEM lubricant specifications:
John Deere - J20C, J20D
AGCO - improved power fluid 821XL
Ford New Holland - ESN-M2C134-D, FNHA-2-C-201, FNHA-2-C-200
Massey Ferguson - M1135, M1141, M1127, M1129A
White Farm Equipment - Q-1826
Case - JIC-143, JIC-145, MS 1206, MS 1207
Oliver - Type 55
Minneapolis-Moline Fluids
Caterpillar TO-2
Renk - Bus Automatic Transmission Fluid
Allison C4
Kubota Super UDT, UDT
International Harvester B6
{from the web}
Greg and John,
Thanks! I am at 47.5 hours and counting till the first 50 hour change out. I really do want a "better" fluid for winter use, but not at the cost of summer use! The Chevron product sounds like the hot ticket.
John Bud
   / Tractor Hydraulic Fluid Data Page #5
John,
Does your owners manual say to "change" the hydraulic fluid @ 50 hrs or just the hydraulic filter?
I'll double check the JD manual, but I thought it said change hy. fluid either 300 or 500 hrs. & the hy. filter @ 50 hrs.
Maybe the "HST" units are different?
And yes, I agree, I'd wait til late Fall for the full treatment of synthetic hydraulic fluid... for the most benefit of your $$$.
   / Tractor Hydraulic Fluid Data Page #6
Hi John,
{I stand to be corrected...}
This is from my JD owners manual on my JD5205:
First 100 hours: Replace transmission-hydraulic filter {Not Oil}
Every 250 hours:Replace transmission-hydraulic filter
Every 1200 hours:Change transmission-hydraulic oil and filter
John,
Kubota service manual states that at 50 hours to change;
Engine Oil
Engine oil filter
Hydraulic oil filter
Transmission Fluid
Front Axle case oil
There's a bunch of Checks and Tightens too.
Thanks for making me check! It's always fun to look into the service manual.
(No, I DON'T get out much, why do you ask?)
John Bud
   / Tractor Hydraulic Fluid Data Page #8
Hi John,
I guess I'm surprised at changing the fluid so early... on the other hand, I don't have a hydrostatic tranny either. So I imagine this is typical of HST's?
Just wondering.../w3tcompact/icons/smile.gif
John,
I dunno, I would think that there is a lot of shear forces acting on the fluid in an HST and at least 3HP of pure heat added to the mix. (power loss greater than a gear tranny) With all that going on, I think its a good idea to change the fluid often!
As they say, your milage may vary...
John Bud
   / Tractor Hydraulic Fluid Data Page #10
Amsoil ATH under applications says "Kubota, UDT - ALL"
Rich
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
