Tractor loss of power
   / Tractor loss of power
this probably helps. note the ground speed. I am shifting thru the gears for reference so you can see 1st/3rd etc.
   / Tractor loss of power #12
If it was the brakes dragging it'd be the same with the PTO on vs off.
Do your tractor have an independent PTO, or live (two stage clutch) or transmission? Are you testing with an implement on the PTO?
"without the load on the PTO it seems to have good low end but as the RPMs climb the speed starts to struggle" could you explain that a little more?
Clutch....the reason a little more power without PTO load is simply that it reduces drag and PTO hp being used. Look and see if there are any clutch adjustments that can be made to your tractor model. I wouldn't use the tractor until such adjustments are made as it will cause more clutch pack damage.
   / Tractor loss of power #13
Yep a slipping clutch would match the description and what I could glean from the video. If the motor was slowing down I'd expect a fuel flow problem. Agree that the clutch adjustment needs to be checked.
The video would be more useful if the was camera in landscape mode.
   / Tractor loss of power #14
Clutch. Definitely. That tractor should have jumped when you let out the clutch that fast,. Make sure to replace that rear engine seal if there is any sign of leaking as well.
3-5TH WHEEL PLATES (A58216)
3-5TH WHEEL PLATES...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
3ft Metal Star (A57454)
3ft Metal Star...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
