Tractor no. 15 !! It will be Cat yellow and have TRACKS !
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #201
Gooder-un! :thumbsup:
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #203
aaaconversion1.jpgaaagraderconversion5.jpgaaagraderconversion3.jpgaaagrader2.jpgaaagrader1.jpgI love cub cadets, it will always be a cub cadet to me.
Todays $100.00 Wheelhorse project had a trashed mower deck but a great engine. Just sitting in a neighbors garage a couple years. I started putting taller tires on it and then decided to tweak it into a grader. I had a lot of fun hammering and welding on this project. Although it has a manual blade lift it is still fun to drive.
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #205
Waldon52 what talent you have amazing work.
Sent from my iPad using TractorByNet
aaamonkeyconversion1.jpgaaamonkeyconversion2.jpgaaamonkeyconversion3.jpgaaamonkeyconversion4.jpgaaamonkeyconversion5.jpgaaamonkeyconversion6.jpgaaamonkeyconversion7.jpgThank you.
As I get older I am almost done building things so it has been fun sharing my last projects .
Todays make over started as a $100.00 Montgomery Wards , after a new fuse and new gas it fired right up after sitting several years in a old shed. We have a tractor similar to this still being used on the farm so I wanted to make one with a narrow front. It is one of my favorites.
aaahotrod1.jpgaaahotrod3.jpgaaahotrod5.jpgaaahotrod6.jpgTodays $100.00 makeover started as a Simplicity . I always wanted to build a hot rod tractor for my little grandson so I did it.
aaafirst110repaint1.jpgfirst110repaint4.jpgfirst110repaint5.jpgfirst110repaint6.jpgfirst110repaint7.jpgfirst110repaint8.jpgTodays repaint project is my first jd 110 , I just had to put taller tires on it . I also had to put a vertical exhaust stack on it . Once all the parts were sanded and painted I did some wiring work on it. To finish it off I built a mid mount belly blade. This is one of my favorites.
aaa110number2-1.jpgaaa110number2-2.jpgaaa110number2-3.jpgaaa110number2-4.jpgaaa110number2-7.jpgaaapaintedframe1.jpgTodays second jd 110 repaint project was $250.00 . It came with a nice working mower deck and a very nice solid snowblower. The mower deck has to be worth $50.00 and the snowblower has to be worth $100.00 . So that means I kinda got the tractor for $100.00 , ha,ha.
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #210
The jd 430 looks much different now with the cab, snowblower and rear box scraper. I am going to try to get 5 thousand for it on Craigslist. <img src="http://www.tractorbynet.com/forums/files/build-yourself/404356-tractor-no-15-will-cat-aaaboxscraper2-jpg"/>
Sounds like a fair price with all your work. You should list it on Antique Tractor Resource Page under photo ads. The antique tractor guys will love it.
Also consider selling it at an auction like Polks.
Payment Instructions (A47477)
Payment...
2020 Kubota BX23S TLB Compact Tractor (RIDE AND DRIVE) (A50775)
2020 Kubota BX23S...
2022 Kubota U55-5 Midi Excavator (RIDE AND DRIVE) (A50775)
2022 Kubota U55-5...
2012 Ford F-350 (A53314)
2012 Ford F-350...
1977 Gleaner A630 Corn Head (A55301)
1977 Gleaner A630...
2022 Polaris Ranger Utility Cart (A55788)
2022 Polaris...
