Tractor no. 15 !! It will be Cat yellow and have TRACKS !
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #381
I mat need the lift handle if I build a front Degelman Silage blade for it.
Todays progress picture shows the new four headlights now mounted in the fenders. Also I build the housings and mounting brackets for the top orange flasher lights on the rear of the fenders. I decided to put one on each fender. I decided today my next project is going to be a 1/2 scale disc or field cultivator to hook to this 1/2 scale jd 4020 with the duel wheels. It will just be for show and I will build it light duty to make it easy to load for parades and tractor shows.:dance1:<img src="http://www.tractorbynet.com/forums/files/build-yourself/438122-tractor-no-15-will-cat-aafenderlights-jpg"/>
For a disk or cultivator. You could buy four garden tractor cultivators or disks like what i use
Or you could do a combination of both. Disk in front and cultivator on back
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #382
Yes, that is a good idea.
Todays progress picture on the 1/2 scale jd 4020 I built a new flywheel shield to cover up the exposed v-belt. I also redesigned the clutch pedal a bit for more clearance on the new wider front tires. aaapully1.jpg
aaashields2.jpgTodays pic shows I got the metal cut out , bent , drilled and painted for the right side shields. Today I will work on the front grill and the front weight .
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #385
Todays progress picture on the 1/2 scale jd 4020 I built a new flywheel shield to cover up the exposed v-belt. I also redesigned the clutch pedal a bit for more clearance on the new wider front tires. <img src="http://www.tractorbynet.com/forums/files/build-yourself/438188-tractor-no-15-will-cat-aaapully1-jpg"/>
How do you do all the fancy designs on the cover ?
aaafront weight 3.jpgNo fancy designs, just basic sheet metal work.
I am very pleased today after seeing the new front grill built , painted and attached. Also I really like the front weights I built yesterday and painted and attached them this morning. The little 4020 is slowly taking shape.
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #387
:thumbsup: Another classic.
Thanks ,
Todays progress shows the new red fuel cap and the new black radiator cap . Also I shortened the lift lever and mounted the steering wheel spinner. And the new much more comfortable seat looks great too.
Today my four new tires and rims should arrive and if all goes well I should get the rear duels mounted for the first time and the tractor should be finished. aaanewseat2.jpg
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #389
Man you don't let the grass grow under your feet! It looks really nice.
aaaduelrims.jpgaaapaintedrims.jpgAt my age I can't afford to just sit around , ha,ha,ha.
Yesterday my four new tires and rims arrived and I got the rims painted yellow. I also got the spacers built for the duels. Almost done with this project . It is far from perfect but it has been another great little project.
2014 RANCO ANVIL END DUMP (A47001)
2014 RANCO ANVIL...
Lincoln Weldanpower w/ Wisconsin Engine (A47809)
Lincoln...
Case International 1896 2WD Tractor (A47809)
Case International...
2022 ALLMAND NIGHT LITE (A47001)
2022 ALLMAND NIGHT...
New Holland 479 Haybine (A47809)
New Holland 479...
2014 UTILITY 53X102 DRY VAN TRAILER (A45677)
2014 UTILITY...
