Tractor placement on trailer
   / Tractor placement on trailer #21
Well guys it is really easy here to overload someones wallet if not his truck. Talking about a 32 foot gooseneck to put a 6500 load is a little outrageous even for TBN folks. .
Naw... you ain't been around long enough.. :) I've seen recomendations for a guy to go out, sell his half ton... and buy a 3/4 or 1 ton truck, new trailer, and about 1000$ of towing goodies to haul a 3000# tractor and a 500# mower.
if the search feature wasn't so bad here.. I could probably link to a dozen posts like that.
if there's anything tbn'ers can do.. it's spend other people's money.. :) :) ;)
( it's talked about on other websites.. :) :) )
   / Tractor placement on trailer #22
A simple way to balance the load is to measure bumper height with empty trailer then move tractor forward or back to achieve the same height. Its not perfect but is not bad. Also play with loading backwards and forwards and look for best fit. Then on first road trip pay attention to any sway at highway speed and if you sway, stop and adjust front or back.
I don't think I agree with that statement. I want to see the bumper of the tow vehicle drop at least a little bit after loading the trailer.
My rule of thumb, and of course its just a rough way to load, it to put the rear axle of the tractor so it sits between the axles of the trailer. This is assuming a tandem axle trailer.
   / Tractor placement on trailer #23
See my post #19 about measure height of bumper, then place a couple of 250# guys on the bumper, measure again. Good distance would be somewhere between first guy on and last guy on without trailer attached. Empty Trailer tongue weighs vary a lot depending on axle placement at the whim of manufacturer it seems.
   / Tractor placement on trailer #24
you want 10-15% of the total weight behind you in tongue weight.
If you wind up with to much sag in the rear of your tow vehical with that much tongue weight, thats why they made WDH. But even with a WDH you still want 10-15% tongue weight. and adjust the WDH so that your rear bumper height is "correct" (see a setup vid on youtube)
   / Tractor placement on trailer #25
a lightweight gn in that size range could easilly hit as low as 3400$, just browsing online. depending ont he exact machines he was hauling.. he may have been MORE than legal..
in a 3500 yes, in a 2500, I doubt it
   / Tractor placement on trailer #26
well, yeah, that will make a difference.. I was thinking 1 ton for sure.. :)
good catch
   / Tractor placement on trailer #27
While I don't doubt that you have done that, it raises an important issue.
Despite the fact that the truck could do that, doesn't mean that it was safe or legal. You probably had 13,000+ lbs on that trailer, that itself probably weighed 4000 lbs. On a late model truck, you may have been close-ish to the numbers, but no way were you legal. Safety is another issue. While it was without incident, that may not always be the case.
I have a good friend that went to prison on manslaughter charges for an accident that wasn't his fault. He was charged because the 2 pallets of concrete and the bobcat on his trailer put him almost 4,000lbs over what the truck and trailer was rated for when he t-boned a woman that blew through her red light.
Sure, we have all overloaded a trailer or put too much in the back of a pick-up, but theres no reason for you not to make the right choice here.
i was just trying to say his truck would handle the load if my can handle the loads i haul
   / Tractor placement on trailer #28
Thanks for the numbers. I was looking at a 20' and it weighs in at 2750lbs, so I think a 10k is too close for comfort. I may go with a 12k or even a 14k.
But with the comments above I may have to revisit the length now as well. Good thing I asked :cool:
Make sure you have a brake controler working correctly.
Ahhh, yes over indulgence to the max. Wouldn't I love to buy a 32' GN and just park the darn tractor anywhere on it. :) But sadly, money is still tight these days and getting a trailer that works for most applications at the lowest cost possible is still somewhat of a priority in my decision. Not that I want to go "cheap", but at least reasonable.
I the most common answers were leaning towards a 14k 20' bumper pull, I will try that size and see how I make out. And yes, I have my brake controller working! :)
   / Tractor placement on trailer #30
i bet even a 12k BP 20' would be fine..
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
Year: 2024 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A56859)
Year: 2024 Make...
S/N: 1240824 (A55853)
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2018 John Deere TX (A53317)
2018 John Deere TX...
