Tractor placement on trailer
   / Tractor placement on trailer #32
Thanks for the numbers. I was looking at a 20' and it weighs in at 2750lbs, so I think a 10k is too close for comfort. I may go with a 12k or even a 14k.
My understanding is your load is comfortably under 7000#. With a 12K trailer you have a good amount of head-room. A 10400# should even be fine and you might consider the cost difference between that and a 12K. Many of the "10K" or "9990#" trailers you see are able to be titled at 10400.
   / Tractor placement on trailer #33
I dont think you will find a bumper pull larger than 12K axles and 20 feet in deck length. When you go larger@24 foot gooseneck, your gonna spend more than $300-400 difference, more like $3-4K difference. I am thinking that with my 20 foot 12K gvw bumper pull,that I can likely haul my 70 HP tractor on it with best weigh I can find is 8500 with FEL. 20 foot length is plenty room for balancing also. I guess I could chop 500 or more off by taking off the bucket or dropping the whole loader and getting down to the 6600 spec for the bare tractor with unloaded tires
   / Tractor placement on trailer #34
i see plenty of 3 axle 30' bumper pulls around here.. small mom n pop car lots use them to drag a couple cars home from auctions. .. of course.. that's about the ONLY people I see using them come to think about it..
   / Tractor placement on trailer #35
We use a 21' double axle bumper pull. It holds the tractor with FEL/BH just fine(see sig for tractor/bh/fel details - bh is on the NH). The machine is not pulled all the way forward but the whole machine fits just fine.
When loaded correctly, the whole thing pulls easy and does not sway.
I am pulling it with a Nissan Titan with a Prodigy 2 brake controller.
   / Tractor placement on trailer #36
you want 10-15% of the total weight behind you in tongue weight.
If you wind up with to much sag in the rear of your tow vehical with that much tongue weight, thats why they made WDH. But even with a WDH you still want 10-15% tongue weight. and adjust the WDH so that your rear bumper height is "correct" (see a setup vid on youtube)
+1 In this case more is better. If 10 to 15% of whatever you are hauling makes the frontend of a 1/2 or 3/4ton light you are WAYYY overloaded. If you don't have enough toungweight you will soon know what duckwalking is going down the first hill. Then you'll either be cleaning your shorts out or be in bad shape from the wreck. CJ
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
72'' SKID STEER BUCKET (A56857)
72'' SKID STEER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
THREE POINT WYLIE SPRAYER (A58214)
THREE POINT WYLIE...
Geismar powered by Stihl (A56435)
Geismar powered by...
Mini Skid-Steer Land Leveler (New/Unused) (A59225)
Mini Skid-Steer...
