Tractor Sizing Tractor pto for 7 foot cutter
   / Tractor pto for 7 foot cutter #52
6ft of MX6 rotary cutter makes my 55HP tractor work hard mowing heavy grass at walking speeds. Front end is light but ok.
A light duty lawn mower rotary cutter maybe one thing. A 7ft medium or HD rotary cutter is way way way too much for a 35HP tractor.
   / Tractor pto for 7 foot cutter #54
For me, 3PH vs pull type has little to do with backing.
If I could guarantee that the only thing I would ever use it for was open pasture with no foreign debris, then it would be fine. But using mine for business, I like to be able to raise it all the way up in a moments notice if I hit something. Stump, fencing, chunk of concrete, bicycle, etc. And also having the ability to to raise it, back over, and lower it onto thick brush/briar patches.
So the choice of 3PH vs Pull should be made AFTER you analyze what you will be cutting.
Now as to cutter size and HP. First and foremost, it isnt an exact science. All cutting conditions are different. And no matter how much HP you have, or how small of a cutter, you will always find some conditions that will bog it down. As evident that some on here state a 7' is a load with 70hp. (10HP per ft). Even if you double that and go 20hp per ft, there are going to be times it is a load.
I run a heavy 6' cutter with 29 PTO HP. And while there are many times I get into thick stuff that will slow me down to 3rd gear (2 MPH), FAR more often I am slowed down by terrain being just too bumpy. I like mowing in 6th gear, which is 5.3 MPH. And frequently have to slow to 5th (4.1 MPH) just because it is too bumpy, or am maneuvering around trees, buildings, etc.
My point is simple. It is my opinion to get the biggest cutter you can run in lighter conditions. Cause you can always slow down. IF you size the cutter for heavy conditions, there is a limit to how fast you can speed up when conditions are light. Those guys running 7 and 8' cutters with 70-80HP, thats fine if you are always cutting heavy stuff. But what about something like this? I was able to mow 6th gear, 5.3 MPH, with 29HP and 6' and it wasnt a load at all. I have no doubt that I could have pulled an 8' cutter just as fast.
<img src="http://www.tractorbynet.com/forums/files/buying-pricing-comparisons/387954-tractor-pto-7-foot-cutter-img_20140815_091918_729-jpg"/>
With 80HP and an 8' cutter, In theory you could go faster. BUT, terrain wouldnt permit much more.
These are just my opinions and observations based on mowing 400+/- acres over the last few years in every type of condition imaginable. And while some may thinl 6' is too much for my 29HP, I have cut some really nasty thick stuff and still have never had to touch 1st and 2nd gear.
You would also be surprised at just how much less power is required by mowing just a 1/2" or 1" higher.
I am actually considering upsizing my mowing outfit as well. And will likely be an 8' twin (for towing purposes), and the L4600 or MX5100 is about the size I would go with.
I could kiss this post!!!!
Both definitely have advantages. Good photo of the top link all the way in. I like the angle. This is why my next tractor will have remotes.
I have had then opportunity to cut various heights as well as thickness of mother nature. One thing not mentioned here. (aside from the 1/2"-1" raise trick"). You don't always have to cut full width of your mower. You can simply shave off a foot, two, three etc. If needed in the thick stuff.
Another advantage of a 3pt is being able to "dangle" over ares which cannot be drive. A wet ditch for instance. Right tool for the job I guess. For what I have done, majority of the time 3pt would be my choice. There have been a job or two where a pull would be better. There are also jobs I've done where it probably wouldn't matter. If I were to ever get a pull type, it would be a MUST to have TSO's hydraulic lift. I raise and lower constantly.
Great posts on this thread. Pretty funny actually
Sent from my iPad using TractorByNet
   / Tractor pto for 7 foot cutter #55
. . . If I were to ever get a pull type, it would be a MUST to have TSO's hydraulic lift. I raise and lower constantly.
Yes, having a hydraulic cylinder to lift and lower a pull-type is an absolute must. I haven't seen anybody in the last 30 years using a pull type without a hydraulic cylinder.
And you would probably find yourself raising and lowering the height less often with a pull-type since the height stays constant on them unlike a 3ph mounted cutter. When I was using pull type cutters, we put "donuts" on the cylinder to limit the amount it could be lowered to the height we wanted to cut at, and then there was no hunting around for the right height. Same thing you do with the position control on the 3ph.
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
STORAGE FEES (A54607)
