OP
hirsch56
- Joined
- Feb 24, 2013
- Messages
- 14
- Location
- Klondike, IN
- Tractor
- Bobcat CT2040, JD 1650, Cub Z-force 48
I do not understand the reluctance to connect things correctly.
But whatever.
No reluctance from me, J.J. That's why I'm here, and you seem to have the most knowledge. Please be patient with me. It will be at least a month before I can get to working on it much, anyway. Right now I am trying to gain knowledge, so when I can work on it there is a good chance it will come out right. I have to get the mower done first, I work most of the day, and take care of my disabled wife most of the remainder.
I was under the impression that I do not need PB if I don't intent to use more than one implement at a time. I'll put the PB sleeve that came with it into the Loader valve (I have those instructions that came with the loader), but I don't have one for the BH valve. Not sure if it even has that possibility. There are 2 INs and 2 OUTs on the BH valve, but one set is permanently blocked by mounting to the frame. Since each is just around the corner from its twin, I assume they both go the same place and are just conveniences for different mounting. Of course I could be wrong. This BH originally was run by a PTO pump, but the shaft broke (my bad!), so I plumbed it to the remotes.
I don't yet understand how the 3PH relates to this problem. Are you telling me the 3PH is fed from the remote return line, so when I max up the hitch, it backs full pressure into the BH and Loader? If that is the case it is no wonder the caps blow out, because there is no stop on the hitch lever. I just pull it up until it loads up the engine, then back off. Do I need to put the 3PH first in the series instead of last? Is that even possible?
There is indeed a port on the tractor which seems to be a sump return. It is presently plugged. If I return the Loader and BH in series to the sump there, will the 3PH operate?
Sorry, I don't have a good way to get a picture which shows much except black. Thanks for sharing your knowledge and experience. I don't have a good manual for this tractor. The rear remotes have long ago been removed and I am using the ports underneath. I got it that way.
