Tractor size for 17 acres?
   / Tractor size for 17 acres? #31
I agree with much of what has been said. As for what size tractor for acreage, acreage has little to do with what you need, it is what you plan to use the tractor for and what implements you want to use. As stated by others, used implements in the 6 foot wide range are pretty common and therefore fairly cheap. I would size my tractor to fit the common implements available. There is really no use in spending $2000 for a new bush hog when you can find plenty of lightly used ones with just some faded paint for $500. This goes for just about any implement used by CUT tractors. I would never suggest a SCUT for any one with acreage over 5 acres. A 30 HP @ PTO will do about anything you want to do except maybe lift large round bales. You really need to set a limit on what you want to lift with FEL and 3PH and let that be a guide to the size tractor needed. HP is not your primary consideration since many, if not all modern CUTs have a series that can vary by 10HP or more with the same frame size, weight and capacity of lifts.
I agree with this line of thinking. I think people get hung up on acreage that you have and think that means you need a certain size. I also agree, 10K is going to be really tough to get by with. I own a BX2350, which is a 23 horsepower Kubota and is a SCUT, which means its really small. It would be tough to find a well used BX2350 with the implements you need for 10K, and its to small for what you need.
   / Tractor size for 17 acres? #32
I have 19 acres, 1/2 in field and yard, 1/2 in woods, spruce, red maple. I have a used NHTC30, 1200 hr that I bought used with 600 hr. 1/2 the price of a new 29 hp LS that I was looking at. I do gravel, tilling, snow, bush hogging and everything I need to,
30hp is a nice size. Gets a lot done. I haven't run into something I can't do.
New is nice - but you spend more. I bought used for 9000 or so. Good luck.
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
200356 (A51406)
200356 (A51406)
KUBOTA ZD1211 (A53084)
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
