tractor size for 600 acres? 1 tractor or 2? cab?
   / tractor size for 600 acres? 1 tractor or 2? cab? #11
You sound pretty married to Kubota. I will say that a regular L or even an MX will feel like a step or two backward vs a Grand L.
If it's in your budget, L6060. I'm not sure about a cab on a tree farm.
What is your budget anyway? That would help a good bit.
   / tractor size for 600 acres? 1 tractor or 2? cab? #13
If you are going to use the FEL a lot, Id look else where.
   / tractor size for 600 acres? 1 tractor or 2? cab? #14
Roger on that, a DK40 Kioti will lift 500lbs more than a MX5800;)
Even the DK 35 lifts a hundred pounds more.
we have a Kioti dealer not far who has a good reputation but a little high, nice man
   / tractor size for 600 acres? 1 tractor or 2? cab? #16
Take a look at Kioti on the RX series, 60 horse 3384lbs lift to full height that beats the mx 5800 by 1100lbs loader lift, and lifts 23 INCHES HIGHER
   / tractor size for 600 acres? 1 tractor or 2? cab? #17
Probably will still be much less then the Kubota. I just bought my second tractor and price out a lot of companies, what Kubota wants over the competition is crazy, especially for a tractor with less capability.
KMC 70Z7 WHEEL LOADER (A52709)
KMC 70Z7 WHEEL...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2014 International Derrick Digger Truck (A55973)
2014 International...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2020 MACK P164T (A58214)
2020 MACK P164T...
