tractor steering problem
   / tractor steering problem
The pedal i was talking about is attached. It is the bottom small pedal. Im thinking this is the problem. It doesnt move too much and I am thinking it is stuck.
Any ideas?
   / tractor steering problem #12
The picture was a bit small so I couldn't see much detail.
How much travel does the pedal have? Can you pull the pedal up at all? Can you see where the pedal and linkage goes under the tractor? If this is the differential lock, the linkage should go toward the rear axle.
Let us know what you find...
yes that pedal does go toward the back of the tractor, the axel im assuming. The pedal only has mabey 1/2 inch of play. Seems to me its stuck. How can I release this pedal.
-=Larry=-
   / tractor steering problem #14
It would be nice to know how much travel it should have. Maybe your friend can answer that....
About all you can do is see if there is any binding in the linkage. If it's all free down to where it enters the transmission or axle, that's about as much as you want to do. It's possible the linkage inside the differential is bound or locked up. Unless you know what you're doing, it's not advisable to go into the differential.
I'm sorry to say this, but it's probably getting close to taking this tractor in to a professional for repairs.
hey all,
just figured out the problem. turns out that pedal behind the gas was the differental lock. it was stuck in the engaged position. after playing with it, i got it free.
Thanks to all that helped.
-=Larry=-
   / tractor steering problem #16
Good for you!!
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A53473)
2019 BOBCAT T630...
2006 Crimson Spartan Fire Ladder Aerial Truck (A52377)
2006 Crimson...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
