tractor suppily weder
   / tractor suppily weder #1
Bandit2026
Ferrum, VA
Ford 8N, Kioti CK35
Wanting a wire welder before I knew better I bought a cheapo from tractor supply. Didn't need something big as I have a new stick welder, a good one. Now in trying to learn how to use this puppy I went to tractor supply and got a resin core tip, won't fit. I also got a pack of .030 tips won't fit. Now what? Also do I switch the pos and neg wires?
Now I know a lot of you will have negative comments but there are people using them and I intend to be one of them!!
   / tractor suppily weder #2
are you running it with gas or without, if running without gas it should have came with everything needed to get started if NEW, and owner's manual will tell you everything to get it going..........you need the right tips for gun, what brand welder & size--and if your not gonna weld a bunch the cheaper unit's will do----I don't see why anyone buys a mig welder if they aren't gonna use gas-crappy welds without gas, My linclon 135plus does a good job on most job's, unless it's something thick enough to need a 220 mig for. with a question for help try giving all info possible...........
Not using gas and it has everything you need to weld but after watching lots of videos they have different tips and some even change the polarity of the cables. Was hoping someone that had one of these would start me in the right direction.
   / tractor suppily weder #4
I have found the staff at Tractor Supply to be very knowledgeable even the part time high school kids. You just have to ask.
As for switching the cables.--- that depends on how they are hooked up now.
   / tractor suppily weder #5
Mig (solid wire) with gas, flux core WITH gas - electrode is positive. Also known as DCEP -
Gasless flux core - electrode is negative (DCEN)
HTH... Steve
Thanks Bukit that's the stuff I need to know. Will check them tomorrow.
I took the cover off and could not determine which was positive or negative as they split off after entering case and had no single point to change.
   / tractor suppily weder #8
You refer to your welder as "a cheapo from tractor supply" their website lists two brands (Hobart and JobSmart). If I read the information correctly for the JobSmart 125 it is a Flux Core only welder? Therefore it should have the ground wired correctly. I did not see anything in the manual suggesting this should/could be changed.
In the reviews - several stated the Tractor Supply tips did not fit. One person said Lincoln tips from Home Depot worked fine. It may be worth your time to read these reviews as they seemed (to me) to give more valuable information than the manual. There is a number to call for problems.
Thanks Shadetree I must have missed that flux core only part. Or better yet it didn't register. Senior moment. I'll drop by Lows and have a look at the tips.
Many thanks Now where can I find a cheater lens??
   / tractor suppily weder #10
Saying you bought a cheapo welder doesnt tell anybody diddly squat. You could at least give the brand and size of the welder. I also suggest you save your money on the cheater lens. I have one in my hood and dont like it. I always have to take my glasses off to use it. I would buy some cheap reading glasses at wallyworld, or the corner drugstore. that way when you take the welding hood off, your not looking for your regular glasses before picking up a hammer to mash your finger with. Done that a time or two.
More info coming soon! (A53421)
More info coming...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
SHOP CART W/CONTENTS (A55745)
SHOP CART...
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
More info coming soon! (A50323)
More info coming...
