TSO
Elite Member
My tractor is a GST and I'd actually prefer that to HST, though I could go with a HST if necessary.
The cab adds unnecessary cost - I think I'll buy a plow truck so I can do my other properties for next winter, so a cab is not necessary right now but would be nice
Ooops! It's actually a DK55 with a KL551 loader. Similar ratings.
That's very true, but part of that is also stability... that tractor has a much larger wheelbase than my skid loader, and ballasted that weight is much further from the lift point.
The skid loader for me has worse visibility... it's very difficult to see/monitor whats behind you, which makes it very nervous for me to work around people/pets. I might miss a small part of the leading edge of the bucket, but I can see the rest.
Only thing in the specs I don't like on the DK55 is the fact the lift at 24" is only 2600 lbs, where as my L3650 is over 2000. 600 lbs seems like somewhat on the low end of an increase between the two models, but I guess it's all relative. I've never been really disappointed in the L3650's 3-point lift so far.
Have you checked out the LS U5030 ? It's a Synchro-Shuttle. 55hp with 48hp @ the PTO. Rear 3pt lift is 4,079 lbs. Loader lifts 2900 lbs to full height. You can probably pickup the open-station version for around $26k. There's also the new Tier4 version of that, the XU5065, which has a hydraulic Shuttle and 65HP... not sure what they're selling for tho.
Loader specs:
Maximum Lift Height, in. 115.5
Clearance with Attachment Dump, in. 84.9
Reach at Maximum Height, in. 27.1
Maximum Dump Angle, deg. 46
Maximum Rollback Angle, deg. 46
Digging Depth, in. 4.9
Overall Height in Carry Position, in. 66.6
Lift Capacity (@ Pivot Pin), lbs. 2900
Breakout Force (@ Pivot pin), lbs. 4790
Approx. Weight (Loader w/o Bucket), lbs. 1276
U5030 « LS Tractor USA
If that tractor came in HST, it would be sitting in my barn now instead of this Massey.
