Tractor weight vs. finish mowing
   / Tractor weight vs. finish mowing #11
I recently posted about this same issue sort of. I was comparing john deere 2520 to a bobcat ct 225. The consensus was john deere if primarily mowing, and bobcat if primarily doing ground engaging work. I ended up splitting the difference on a new Branson 2400H. I felt it had good weight for my ground work, and still light enough for the mowing aspect. It weighs in at 1811 dry weight, plus the loader. I figure around 2400 lbs maybe?? I have 6.5 acres, split pretty evenly with woods/grass. I needed something small enough to maneuver the woods, but still big enough for ground work. After looking at the bobcat, I realized it was too big for me.
   / Tractor weight vs. finish mowing #12
Approximately 4,300lbs (not including mower)....no problems unless the ground is really wet, or I don't pay attention, and make really tight turn (like one tire nearly stopping). I have some R3s I'm thinking of trying ($200 for the set with wheels!) to see how they do when it's a bit wetter.
   / Tractor weight vs. finish mowing #13
I mow my place with my L5240 and a 72" RFM, if I have time or am not using it I take the loader off as it makes it easier to maneuver. I don't have any issues with rutting unless it is extremely wet. I just mowed Thursday evening after work after it had rained that morning and while I had to be careful making tight turns because of the wet ground, there was no rutting problems. If I had R3's instead of the R1's I don't think it would be any concern. My tractor weighs in about 5000 lbs with the loader and RFM on. While it is a big machine to do finish mowing it handles so many other larger chores with ease that I can do all I want with only one machine.
Here is a picture without the loader.
   / Tractor weight vs. finish mowing #14
Looking at a Dere 5505E for serious yard/clearing work, but want to finish mow as well. With R4 tires, is this thing too heavy for grass on sand (north central FL)?
   / Tractor weight vs. finish mowing #15
I finish mowed with my L3710 Kubota on R-4s but only in a 3 acre front yard where I wasn't concerned about some scraped ground I and bare spots in corners. This is on heavy clay soil which I believe is a lot harder to rip up than your sand. I think it all depends on the quality of cut you want. Everything around our house gets cut with our JD riding mower to get an improved look.
   / Tractor weight vs. finish mowing #16
On sandy ground I think a 5505 might leave some marking. Like MHarryE said, what type quality cut are you looking for?
   / Tractor weight vs. finish mowing #17
I am currently mulling over this same issue but will be mowing with a JD 5210 MFWD tractor with a self leveling loader attached I am searching for a set of r3's since the r1's I have are very sharp and leave pretty good impressions. my tractor is 53 HP with 47 on the PTO . currently trying to figure out weather I should get a large rear finish mower or a 6-8 ft flail . we live on a residential airport with a grass field and take turns mowing it my b7100 is broken currently but to small for the runway task
   / Tractor weight vs. finish mowing #18
Was at the dealer yesterday trying to make marks or ruts on his lawn with the Deere 5055. The R4s appear to distribute the weight very well; no ruts or marks. Obviously trying here to combine two inconsistent functions: finish mowing (for which a 20 something hp with a belly mower would be fine) and ground work, for which bigger power is needed. Also really like the A/C cab of the 5055e -- hot here in FL!
   / Tractor weight vs. finish mowing #19
For mowing a runway, I'd go with the widest mower you can manage. I help my neighbor with his runway a couple of times a year....he runs a 6' mower behind his tractor, and a 5' mower on a side tagalong, so he's getting 11ft per pass. I'll line up my 7.5' mower behind him, and we're getting 18ft per pass, and it still takes a while.
Flail mowers won't give you quite as perfect a cut as a finish mower, but would seem to be a good fit for what you're doing...I'm considering one for a couple of large areas I keep mowed, but aren't my actual lawn.
   / Tractor weight vs. finish mowing #20
Yes the widest without being to much for my tractor think 8 ft multi blade finish mower maybe a 7-8 ft flail not sure or how my tractor will handle either it seems to handle a 5ft tiller easily though... I have used my neighbors massey with a 6ft rears flail a couple times but not on my tractor would sure like to get a chance to see how it would run a 6 ft then I would have an idea if it would pull a 7 or 8
2025 SDLanch SDLL30 Mini Stand-On Track Loader Skid Steer (A56857)
2025 SDLanch...
500 Gallon Pasture Sprayer (A57149)
500 Gallon Pasture...
Champion Gas Powered Auger (A57454)
Champion Gas...
2025 Leopard F50 X-pro Mini Dirt Bike (A56859)
2025 Leopard F50...
(2) Auger Bits (A57149)
(2) Auger Bits...
(50) UNUSED FUTURE 3'X12' CORRUGATED METAL SHEETS (A58376)
(50) UNUSED FUTURE...
