tractor wont run
/ tractor wont run #2
If you have a manual start reading about bleeding air from the fuel injection system.
If you ran it out of fuel this will happen.
Contrary to a gas engine where you just add fuel when you run out, the diesel requires the air bled from the system.
Dave M7040
/ tractor wont run #4
Remember to give the starter some rest time, or you'll be replacing a starter also.;)
/ tractor wont run #5
Make sure that you fuel delivery system is actually delivering fuel to the injector pump. The usual culprits are a clogged fuel tank strainer at the tank bottom, a damaged fuel line between the fuel tank and the fuel filter, the fuel filter itself, damaged line to injector pump, fuel lift pump screen clogged, etc. some time it's only a partial clog andi t allows enough fuel to start bt can's supply enough to run continuously.
If you have a solenoid valve in the fuel delivery system( i.e. if you stop the engine by shutting off the key) make sure the solenoid valve is opening with the key in the start and run position.
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
John Deere 5525 (A60462)
John Deere 5525...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
