Tractor won't start
   / Tractor won't start #11
If this is a hi-jack, let me know and I'll start a new thread...
My Dad bought a new lawn tractor to replace his old MTD 18HP. As long as he wasn't using the MTD, I figured I'd take it and try to get it running. Figured I could always use it to haul a cart, or let the kids drive it around.
Anyway, the MTD won't turn over. After going through a couple of batteries, my Dad had the charging system was replaced a few years ago. I have a strange feeling the current problem is electrical also. (no pun intended)
Just wondering if it would be possible to weld a pully to the flywheel nut on top of the engine and use a pull cord to start the tractor. Since it's now an 'extra' tractor, I don't really want to put any money into it. And with a pull cord, the kids would not be able to get it running without my help, so I would be sure to supervise their use.
Thanks,
Doug
   / Tractor won't start #12
Usually there is a cup that bolts on with the flywheel bolt that you wrap the ropre around, thats a no-weld solution.
You could weld a pulley on there, but it would be hard to get the nut off it you ever need to.
   / Tractor won't start #13
I haven't had a chance to work on this too much yet, but I did pull the deck off. Just thinking I could use the pully that drives the mower blade belt for a pull start...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
Single Cedar Glider (A57454)
Single Cedar...
Sedan (A59231)
Sedan (A59231)
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
