Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #121
hey scotty I have a yanmar 4220D with the stock wheels like you had with ag tires I also was thinking about turf tires, how did you figure out what size wheels and tires you needed for the 4 wheel drive gear ratio from front to rear,since the stock wheels are metric
   / Tractors and wood! Show your pics #122
Been busy...
Dropped a huge poplar today. Took 3 hours to drop, drag, chunk and split into manageable pieces so I can lift on trailer. I have another 6 large trees to drop in the next 3 days.
Hopefully I can get about 4-6 cords out of this stuff.
I saw through the trunks and split with a wedge. Large pieces I can just lift onto trailer. The first 3 pics show a bit of clean up after the local utility topped the trees to fix a line and left a mess. Last 3 are of tree removal for neighbours.
   / Tractors and wood! Show your pics #123
Fenders are standard IH for the time, It is a 1950 and still has flat tops in it.
Thanks, Kevin,
Ours were all purchased used in the late 40's and very early 50's, so the fenders hadn't appeared by the time they were made.
Terry
   / Tractors and wood! Show your pics #125
Finally figured out how to post a picture, here is a shrink wrapped skid. Clarington-20140215-00123.jpg
   / Tractors and wood! Show your pics #126
I got tired (old and lazy) of going into the bush to get my wood. I now have a logging truck bring in a load every four or five years.
Fred
   / Tractors and wood! Show your pics #127
image.jpgimage.jpgimage.jpgThis is my 1958 Case 310B That I've been using for the last few years to process my cord wood. And a photo of its replacement that I added two days ago. 2008 ASV PT-60 under 500 hours.
   / Tractors and wood! Show your pics #128
First trailer load. Loaded, unloaded, split and ready for the kids to stack tomorrow. Will get another load in the PM. 30% pine / 70% hardwood.
The second pic is the 'view" - always good to have when taking a short break.
   / Tractors and wood! Show your pics #129
Lloyd_E
That some scotch on ice in the third pic? Good to have something when enjoying the scenery. :)
   / Tractors and wood! Show your pics #130
Dropbox Images from building a Rebak
https://www.dropbox.com/sh/kxj2l6i99zj8had/eyyIYZnSGy
Overload clutch built into the flywheel is under counstrucktion, the next becomes a belt conveyor to load material backwards in a carriage
and a small circular table with power feed to cleave the bark wood from Snik saw that very often is over 180 mm wide
the chipper takes 180x 110 mm 7.0x 4,3 inches
a Rebak is a Polish invention not so common in Sweden, so you have to build it your self
when the flywheel with overload clutch is finished we shall make at test run :dance1:
2015 CATERPILLAR 299D SKID STEER (A51246)
2015 CATERPILLAR...
1996 UTILITY 101" X 52' T/A FLATBED TRAILER (A51247)
1996 UTILITY 101"...
UNUSED INDUSTRIAS AMERICA HI100T HYD TILT LAND LEV (A51247)
UNUSED INDUSTRIAS...
RIGID TOOLBOX (A52472)
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
