Loaderman22
Veteran Member
- Joined
- Jan 11, 2017
- Messages
- 1,016
- Location
- Hudson Valley, NY
- Tractor
- 1947 Ford 2N, 75 MF 30B, 75 Swinger Loader, 1979 Cat D3
I don't think that trailer is going to roll all that easy...
Do you have to get all lumber used in "residential" (habitable) building graded and signed off by an engineer like we do here? If a building inspector walks on a site he needs to see all the grade stamps on the lumber. If no stamp, then (s)he needs a letter from an engineer who is certified to grade lumber stating that it is ok to use for the application.It was another nice day out today, I made lumber!
Here's one of the logs, headed to the BSM,
With it loaded on the mills deck, I made the first cut,
and then went around, taking slabs off to make a cant,
With a cant made, I started taking 2x12's off,
With a few more logs milled, I started to get a nice pile of lumber built up!
All of the slabs, get cut up for firewood,
SR
Sorry made me laugh. While I do not know the OPs situation, out where I live we don't have that. Actually we don't have building codes, permits, inspections or any of that stuff. I have 92 acres and if I want a new sewer system, road, building, electric, well or water lines, I just do it or hire it out. Now the county assessor visits every property every year or two in person to see if they can charge your more.Do you have to get all lumber used in "residential" (habitable) building graded and signed off by an engineer like we do here? If a building inspector walks on a site he needs to see all the grade stamps on the lumber. If no stamp, then (s)he needs a letter from an engineer who is certified to grade lumber stating that it is ok to use for the application.
Short answer is yes, IF it's for a house, but not if it's used in an outbuilding or a barn.Do you have to get all lumber used in "residential" (habitable) building graded and signed off by an engineer like we do here? If a building inspector walks on a site he needs to see all the grade stamps on the lumber. If no stamp, then (s)he needs a letter from an engineer who is certified to grade lumber stating that it is ok to use for the application.
"Some" building codes don't bother me at all. I've seen plenty of buildings that were built in no code areas by homeowners, and most were everything from terrible to scary built.Sorry made me laugh. While I do not know the OPs situation, out where I live we don't have that. Actually we don't have building codes, permits, inspections or any of that stuff. I have 92 acres and if I want a new sewer system, road, building, electric, well or water lines, I just do it or hire it out. Now the county assessor visits every property every year or two in person to see if they can charge your more.
I agree the codes make sense, and living in area with none means everything has to be looked at. I see lot of non electricians do horrible and dangerous stuff. Same goes for rest. Now I like to look at the national code exceed minimum and go from there. It is nice however to build a machine shed or pole barn without permission. Even house if YOU are willing to do the homework and make sure it is done "right". I know not to trust anyone to do things how I want and don't need to pay someone from GovCo to look at it."Some" building codes don't bother me at all. I've seen plenty of buildings that were built in no code areas by homeowners, and most were everything from terrible to scary built.
There are you-tube channels of some of those areas, like one in Louisiana that is now milling out 4x4's from pine and sticking them in the ground and cementing them in! They don't believe they will rot and have several buildings built this way, including their house.
That's just one example where minimal building codes wouldn't hurt.
SR
