groundcover
Veteran Member
Just chip trashy, punky stuff that big as a rule, firewood the rest . But a good bit of cord wood has gone through her as well !
I could keep that DitchWitch 752 with grapple busy for about a year ....And for the ones too big for the chipper .
When you say wandering have you tried starting it in the cut then letting it go without a hand on the top handle to see if it’s you or the saw causing the wander?I want to cut a few "cookies" off the butt end of the log with the blue stain. For tables, etc. I've never done that before.
How do you get a good square cut? Seems I should start by squaring up the open/butt end of the log. I'm terrible at that with a chainsaw-- the saw wanders around as I proceed down through the cut.
I have a bandsaw mill-- is that a better option? Cut maybe a foot off the end, then place it on the mill so the log is vertical? Then use the bandsaw for the cuts?
I will try that in the next cuts .... thanks!have you tried starting it in the cut then letting it go without a hand on the top handle
WOW! Man that thing can do some work!View attachment 771721Haven't used my tractor in the woods very much since I got the Witch !
