Trading
/ Trading #1
Buppies
Super Star Member
SouthWestern Virginia
Kubota L5240 EX mark 60 in 29 hp Toro 60inch Z Master 21 inch walk behind Polaris 900 hunter edition 30in toro walk behind
Would you trade finishing mower 1672 land pride used only twice, kk bush hog 5 ft , 60 in box blade bush hog brand and 50-07 bush hog for TNT on rear and wheel weights or would you try and sell outright . All but blade are to small for current tractor
/ Trading
I would really like to have some opinions to see if my logic is correct or is this a mistake as I am prone to make
/ Trading #3
You are right you want implements at least as wide as your tires. A scraper blade you will want it to be wider so when it is angled it is still as wide as the tires. You are going to need some good stuff to hold up to your tractor. Is the finish mower not wide enough?
/ Trading #4
With the blades usually 1 foot longer that the tractor width compensates for the angling loss.
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2012 JLG G9-43A TELESCOPIC FORKLIFT (A64279)
2012 JLG G9-43A...
2018 John Deere R4030 Sprayer (A63111)
2018 John Deere...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
3PT HYD SCRAPE BLADE (A63291)
3PT HYD SCRAPE...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
