trailer ball capacity / shank size
   / trailer ball capacity / shank size #21
Capt. Dan,
Good point. Let me share a story with you.
Recently, My cousin asked me to move a large travel trailer (park model) for his grandson. Dry weight on the trailer is over 11,000#. I told him that we needed a Class 5 (15k) ball and ball mount. (my F-350 has a Class 5 hitch) He asked, "What for? NOBODY uses stuff like that." I explained that I would not move the trailer without the proper ball and mount. (I didn't have one because all my heavy trailers are G/N) He grumbled around for a few days and then ordered one. Then, I gladly moved the trailer for them.
Point is, I don't think MOST people understand the difference in towing equipment, or even know what they have.
Again, good topic. Maybe someone will read this thread and avoid future problems.
   / trailer ball capacity / shank size #22
Etrailer.com 2 5/6 balls by capacity:
Gross Trailer Weight Capacity
10000 lbs GTW (14)
12000 lbs GTW (6)
14000 lbs GTW (3)
15000 lbs GTW (1)
16000 lbs GTW (1)
2000 lbs GTW (3)
20000 lbs GTW (8)
24000 lbs GTW (2)
25000 lbs GTW (5)
30000 lbs GTW (20)
6000 lbs GTW (1)
7500 lbs GTW (1)
8000 lbs GTW (2)
2-5/16 Inch Diameter Ball Balls | etrailer.com
Bruce
When I was looking it was back in 2007 and they were very scarce and only found the REESE PRO SC equalizing hitch rated for 14k and had to add the Super Hitch receiver for the 15k rating, now all the big 3 have the 2 1/2 hitch receivers.
David Kb7uns
   / trailer ball capacity / shank size #23
Neighbors Suburban came with a 2 1/2 reciever from the factory... at first he was a little miffed about it because he had everything for the 2"
He tows about 600 miles a week and looking back appreciates the heavier components.
I'm guilty of this and have to learn how you quote.
"Originally Posted by tcartwri View Post
And how many of you have the tools to torque these fasteners properly..."
I've have never put my old 1/2 inch beam torque wrench to a trailer ball. Need to check it's capability. Usually put mine on with a 24 inch long breaker bar. Don't think I've used a cheater bar to install a ball. Am I getting a 1 inch shank close to torque? How often do they get over torqued?
I have stopped cars twice for a loose ball. Once was in Utah towing a U-haul to east coast.
Dan
   / trailer ball capacity / shank size #26
Or even know the specs?
My 14K equalizer
Hitch balls require a 1-7/8 socket and a torque wrench capable of
approximately 430 ft-lbs torque for installation
So I just put a 24" bar on the big socket and put most of my weight on it
Dan
A torque wrench for 430 ft lbs to be used once a decade is expensive.
   / trailer ball capacity / shank size #27
Actually got the Harbor Freight 3/4 socket set for this and put the stinger in the receiver on its side and step on the wrench handle until tight, think one of the balls had a spec of 480ft lbs so 2 foot handle and 240lbs will do it.
David Kb7uns
   / trailer ball capacity / shank size #29
Well, I'm down to one hitch brand. B&W, I've got a flip over with a 2 and 2 5/16 rated for 10,000 pounds and 1000 pound tongue weight, that's fully height adjustable, and a flip- over gooseneck from them. There stuff is top quality. LUTT
   / trailer ball capacity / shank size #30
I think for some folk "I can't bend it by hand" becomes "It can't be bent". Sadly, there's a vast spectrum above that demonstrated daily in "accidents".
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2014 Walker Compactor (A55787)
2014 Walker...
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
2003 MACK RD688S MIXER TRUCK (A55745)
2003 MACK RD688S...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
