Trailer Ball Mount or Receiver Hitch to replace bucket on BX25
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #11
I don't move a lot of trailers so I just hook the safety chains on the bucket. I could see a ball hitch if I did........JB.
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #12
I had a 2" receiver mounted on the top of the bucket. This was nice as it stayed out of the way. The down side is a drop hitch is required.
I have a 3pt 2" receiver that gets used 90% of the time but the front is nice if I need to use a trailer and dump what's on it. I'd rather pull a trailer a back the tractor personally.
It does have its purposes though so I had another receiver mounted on my newer tractor as soon as I got it.
Also, with a 2" receiver, you can make different attachments. Short boom poles etc....
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #13
I mounted a receiver on my pallet fork attachment and it works quite well, sorry no pix.
Fred
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #14
Before you go through all the work, chock the tires of the trailer and then make sure your loader has the strength to lift the tongue of your trailer. My B26 won't lift my 5th wheel.
   / Trailer Ball Mount or Receiver Hitch to replace bucket on BX25 #15
I have every intention of making an attachment very much like clamp on forks.
It will span width of space between 2 bucket teeth and use one hefty screw down clamp (maybe 2) meaning that this U shaped thing will be about 7" wide (tooth spacing) with a 1/2" X 3" flat sticking out front with a hole for the hitch ball. Might use 2" I.D. square receiver tube so as to change sizes easily.
Promise to post pics when done.
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
TAYLOR TDF-60S STRAIGHT MAST FORKLIFT (A51242)
TAYLOR TDF-60S...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
