Trailer Brake Problem/Question
   / Trailer Brake Problem/Question #11
There is too much guessing going on now. You really need a 12V test light and volt meter. You can get both for under $10 at Harbor Freight.
Chris
   / Trailer Brake Problem/Question #12
my 3 controllers all lite up when you hit the brakes.. either with just a dot or a code showing no trailer.. then with trailer on.. they show percentage or level of brakes.
   / Trailer Brake Problem/Question #13
Check your Ford owners manual , If I remember correctly , there is a fuse in the fuse box under the hood , and a fuse in the fuse box under the dash / of behind kick panel . Check all fuses / boxes . Hope this helps .
And the winner is...
(Actually winners): George2615 and Radioman with honorable mention to Dr. Dave. The new controller (even though the literature says otherwise) does not light up at all until hooked up to the trailer. Green when connected, turns to red when brakes are applied.
Dr. Dave gets honorable mention for the fact that after my testing them in the driveway and one not leaving a skid mark with gain turned all the way up, I revisited the wiring and one side ground was loose.
Soundguy, I guess I bought the cheapie this time that doesn't provide constant visual feedback (if you consider $92 cheap that is).
Thanks for the input - David.
   / Trailer Brake Problem/Question #15
maybee.. maybee not.
I have 2 hoppy.. one with 3 led's, and one with a led readout. cost was 35 and 50 ( 7 ys ago ).. cost now is 50 and 80..
both of them light red indicators when brake pedal pushed and no trailer.
I have a drawtight that has a red dot that lights when brake pushed and no trailer... 100$
same with my prodigy.. 100+$
I see walmart has a unit now.. have not tried it.. but know a guy that has one. it stops his trailer.. but I don't know about the readout.
I'd not call it a 'cheap' issue.. just a matter of design on what it 'reports' or not.
glad you got it fixed.
soundguy
   / Trailer Brake Problem/Question #16
Glad you got it fixed. Well, I guess it was never really broken but anyway.:thumbsup:
Chris
Honda EM3800SX Portable Gasoline Generator (A55851)
Honda EM3800SX...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2005 Peterbilt 387 with Wet Kit (A57024)
2005 Peterbilt 387...
24017 (A56859)
24017 (A56859)
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A57193)
UNUSED FUTURE...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
