trailer brakes
   / trailer brakes
Also, what did you do to your drums? The first line of your post states you replaced everything new, EXCEPT, the drums. Did you have your drums machined to give a concentric diameter with a new surface to mate to your new shoes? If not, that's part of your problem. The drum contact surface needs to be de-glazed when installing new shoes. Otherwise all you will get is polished new shoes. B.
I did not do this. Where do I get this done? Does everybody do this or just some people?
   / trailer brakes
update; I took a set of jumper cables and jumped the working side across to the nonworking side, bypassing the wire through the axle. I got power to the magnets verified by the humm. So I started checking for continuity through the axle wires. Could not get any continuity. Then I noticed something not seen before. The wire that goes through the axles was double shielded. I had only stripped the outer down to the clear. All my crimps with the double shielded wires had to be redone. I am at that age when glasses will have to be kept in my toolbox. Got plenty of braking power now. Thanks for your posts
   / trailer brakes #14
I fuss when I have to wear glasses working on equipment.
   / trailer brakes #15
......... Then I noticed something not seen before. The wire that goes through the axles was double shielded. I had only stripped the outer down to the clear. All my crimps with the double shielded wires had to be redone. ......
:laughing: Sound exactly like something I would have done. Hate this far sightedness.
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
2015 Freightliner Derrick Diger Truck (A55973)
2015 Freightliner...
2017 Komatsu WA500-8 Wheel Loader, S/N A96097, PIN# KMTWA134LGNA96097, Komatsu Turbo Diesel Engine, (A59076)
2017 Komatsu...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2012 DIAMOND C 40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
