Dr Dave
Platinum Member
It seems that some are projecting a trailer with full emergency brakes activated that is still attached to the tow vehicle is possible or likely to skid out of control. As the OP stated it smoked big time and he pulled over and determined what happened. No dangerous skid just locked up brakes. If a trailer is behind the tow vehicle and still attached and all 4 brakes lock up symmetrically ( which they should) the trailer will not skid out of control unless the tow vehicle locks up all it's brakes and steers violently to the side. The trailer becomes a dead weight with a lot of friction but should track straight as the tow vehicle brakes to a stop. The trailer tires will most likely be destroyed depending on speed at lockup but there should not be a transverse skid unless only one side brakes lock. Thus I do not see how you can compare the risk to not having the emergency cable connected. Matter of fact I see no risk at all. If you have not checked the status of the battery powering the system you might want to do so they do not last forever.
Years ago the trailer shop that help me with my first trailer with emergency brakes showed me how to take the cable thread it through a ring hole on the tow vehicle hitch and then return to a clip that could be attached to a link on the safety chain and thus could adjust the length as needed.
I have wondered about that but it seems a common practice and is normally on a link that is 2-3 from the trailer attach point. Since the cable would be pulled prior to chains going tight it seems ok. What do our two experts (Dr Dave and soundguy) think of that technique.
This would work if you or anybody hooking up had the cable about 3" shorter than the chain length. But can you be sure every time? I find it is best to cut the cable to the proper length. If there is not a good atachment point for the cable, you can install an eye bolt on the bumper. Good point about the battery, all our trailers have been fitted with a solar charger, and inspected twice a year.
Dave
