trailer SPRINGS, going over instead of under
   / trailer SPRINGS, going over instead of under
John, Thank you for that info. I'll check on updating the existing elect brakes (they are on the front axle only) and if they are too extensive (since I flipped the axles) I guess I could install a fresh set on the REAR axle and leave the front axle disconnected?? Is there a reason that the orig brakes are front axle only? I guess maybe the weight pitches forward....:confused2: What does the controller thing need to work? power in and......then just a line to the brakes? How do it know when to apply....is it also connected to your brake pedal or brake lights or or or?:confused:
   / trailer SPRINGS, going over instead of under #22
You should post in trailer and transportation sub forum. That's where the trailer jockeys hang out... Diamondpilot knows this stuff cold, for one.
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
2007 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A60429)
2007 KOMATSU GALEO...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
