Trailer warning, this could happen to you
   / Trailer warning, this could happen to you #91
I like my bumper pull trailers way more than a gooseneck. They’re way easier to hook up for the main reason. I can’t load the bed for the second reason.
Not sure how a bumper pull would be easier to hook up.
Between the mirrors and the seam in the middle of my flatbed I can see if I'm correctly positioned side to side. Then it's guesswork for the last two feet or so, and the auxiliary tank doesn't help, but I rarely miss by more than one or two inches lengthwise.
To me it's much harder to hook up a bumper pull, partially because I'm almost completely out of practice doing that. Maybe once a month on average, and that's with smaller tow vehicles.
Also, for me the ability to have anything on the bed is irrelevant. Never had anything on it in eight years and that's not likely to change. What will change is that I'll make a minimalistic bed for the 3500, basically a gooseneck hitch, fenders, taillights, and a couple of toolboxes. That's all I need and want.
   / Trailer warning, this could happen to you #92
I have a backup camera for the bumper hitch ball. If I pulled the GN very often I’d add a second camera but for now I’m backing blind when I hook it up. I only have to run the jacks on the BP trailer the bare minimum to get it to clear the ball. With the GN I have to lift it another 6 inches or so since the ball is recessed in the bed. I also have to get on the bed to latch the ball and hook the chains where the BP doesn’t require that. I also have to get out of the truck before even starting and open the cover in the bed.
   / Trailer warning, this could happen to you #93
Many "silicone's" will cause corrosion, they have an acetic acid base that citrus smell that you smell while working with it. A latex caulk will not cause corrosion
Yep, a "neutral-cure" silicone is best for most applications, vs the cheap stuff.
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
John Dozer JD650 (A51691)
John Dozer JD650...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
New Holland B95 Backhoe (A50490)
New Holland B95...
Electric Mobility Scooter (A51694)
Electric Mobility...
