Tranmission/ Hydraulic Fluid
   / Tranmission/ Hydraulic Fluid #1
mark4Jesus
Sale Creek, TN
2021 Branson 2610h
I had Bush Hog FEL installed on my B2150. They topped of the trans/ hyd. fluid. This is not where I bought my tractor. The manual says not to mix different brands of fluid. Is this really a problem? Do I need to change the fluid?
   / Tranmission/ Hydraulic Fluid #2
I seriously doubt you'll have any problems, Mark. I assume "they" are the dealer, and most of them know what they're doing.
I'm for Jesus, too! /forums/images/graemlins/laugh.gif
The FEL was installed by a local farm supply dealer, not a Kubota dealer. I'm not sure why the manual says not to mix fluid from different manufacturers.
   / Tranmission/ Hydraulic Fluid #4
Mark, I'll look into this tomorrow a.m. Get back to you tomorrow p.m. /forums/images/graemlins/wink.gif
   / Tranmission/ Hydraulic Fluid #5
If you had a tractor with remotes and "Billy" borrowed your hydraulic harrow some of his "Hy-Tran" would be left in your harrow lines and cylinder(s) and it would be pushed into your system as soon as you operated it. It's probably not a good idea to mix fluid, but most tractor hydraulic fluid is compatable with each other. Super UDT is fairly unique, you will find some threads however where the Kubota dealer would recommend Hy-Tran or New Holland tractor fluid in place of Super UDT.
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
UNUSED LANDHONOR RGB-11-72W - 72" ROCK GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI GY-PG72C...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55218)
2021 John Deere...
