Trans fluid in my wod splitter
   / Trans fluid in my wod splitter #1
wesmann
Western Massachusetts
YM 276D
Time to change my YM 276 trans fluid (300 hrs). Hate to throw it away. Can I use it in my Didier wood splitter? Splitter has a four or five gallon tank and have no idea how old that fluid is.
Thanks
   / Trans fluid in my wod splitter #2
I would say yes but why? Is it worth a few bucks worth of hydraulic fluid to ruin the pump of your splitter.
   / Trans fluid in my wod splitter #3
I would use it. If it was good enough for the tractor a few minutes prior it’s definitely good enough for the wood splitter.
   / Trans fluid in my wod splitter #4
Are they the same oil types? Most splitters now a days use automotive style trans fluid not tractor hydraulic/trans fluid. My splitter uses the automotive "red" fluid. That's what they recommended so that's what I put in since I had to buy it anyways. Probably doesn't matter, but wouldn't want to mix different types.
   / Trans fluid in my wod splitter #5
Mine uses hydraulic fluid, I do admit to putting cheap stuff in mine.
   / Trans fluid in my wod splitter #6
IF the oil isn't good enough for my tractor, it's NOT good enough for my splitter either!!
SR
Thanks all - Advice for and against... Can't stand to throw it out. Bought the splitter way used. It's probably 40 years old. I have no idea what's in it but the manual says to SAE 30.
Plenty of time to think about it. It's snowing.
   / Trans fluid in my wod splitter #8
If it says to use SAE 30, why not just use SAE 30?
It is cheap enough.
   / Trans fluid in my wod splitter #9
Our splitter said to use Dexron..
------- Cheap compatible is acceptable..
-------- At that age maybe it deserves a new fresh oil change..
   / Trans fluid in my wod splitter #10
If your replacing the oil in the tractor then it is used up. Putting it in another piece of equipment is like taking a sock with a hole off one foot and putting it on the other.
The tractor uses trans-hydraulic. The splitter most likely uses hydraulic oil and it is not advised to mix oil.
Here is a link to replacement log splitter pumps should you need one.
2 Stage (Log Splitter) Pumps | Hydraulic Pumps | Hydraulics | www.surpluscenter.com
As a comparison 5 gallons of hydraulic oil is in the mid $30 range.
UNUSED INDUSTRIAS AMERICA R2232X 12' DISC HARROW (A57192)
UNUSED INDUSTRIAS...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
2020 JOHN DEERE 85G EXCAVATOR (A52707)
2020 JOHN DEERE...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
Pallet of (5) Dora Trench Drain Grates (A56469)
Pallet of (5) Dora...
