Tree Puller: Pleased with my new Attachment
   / Tree Puller: Pleased with my new Attachment #11
Pretty slick operation on those trees. Thanks for posting the video.
Looks like it is about 1/3 - 2/3 centering on the smallest trees, bigger trees would be more centered than that, that doesnt seem like a real killer off center. It seems if there is enough grunt to pull it up by the roots carrying it should be OK ?????? I'd be more concerned with keeping it upright if it were real tall no matter where it was centered.
It is slightly off-center, to the right. I notice my left rear wheel lifting off the ground when I attempt to pull out a tree that is too large. That surprised me because I thought the lift capacity on the loader would constrain me.
I have a JD4105 with a 300CX loader. Yesterday's ballast was a 74 inch Flail mower -- I will go heavier next time.
Mostly, I have willows to extract -- small, but too big to bush hog. They are tall, pretty straight and I'm thinking about putting the chipper on the back (3PH) and after uprooting each tree, I'll chainsaw off the rootball and chip the whole tree 1-2-3!
   / Tree Puller: Pleased with my new Attachment #13
Louie,
How much does this weigh?
Mine weighs about 300 lbs -- one of the reasons I chose this design was it's light weight -- so my lifting capacity wasn't consumed by the attachment. Also the tree is close to the pivot point on this design.
It is my understanding that the 3-point hitch option I chose added 50 lbs. I can hook-up on the front or back.
The cost was $1450 plus $200 for my option plus shipping. Customizing for my loader was included in the base price. I will get my money's worth out of this thing before I run out of trees!
   / Tree Puller: Pleased with my new Attachment #15
Wasn't there some-one on this site looking for a tool to pull tent stakes...............this would be perfect.
I have acres of Buckthorn....I sure could use that attachment.I have found them to be very deeply rooted and don't believe I could pull with my FEL.
   / Tree Puller: Pleased with my new Attachment #16
Thanks for the info Louie, That weighs less than my grapple.
Seeing that you have a grapple (or at least I think you do) how much better does this work than using the grapple to push over and uproot the small trees? I think that price is very reasonable for how much work you will get done with it!
How fast/slow is the cylinder when you open and close it? I imagine with this tree puller, and the HST transmission, you could clear out a good amount of small trees in a short period of time!
Did you also have a tree shear at one point, or was that someone else?
   / Tree Puller: Pleased with my new Attachment #17
If you have a lot of trees to pull, that's a very handy implement. I have very few to pull so I do it the old fashion way. Chain wrapped around the base of the tree several times then attached to my bucket hooks on each side of the bucket. With the bucket flat on the ground I give it a full curl and out it comes. If it needs more - I attach with the bucket in a full forward curl and go to a full rearward curl. The only problem with this is I have little control of the tree after its pulled from the ground. And if I had a lot of trees to pull I'd be up/down from the op seat like a yo-yo.
Piston,
I do have a grapple. I used it to pile-up all of the trees I pulled yesterday. As for digging, it is not very precise due to lack of visibility. I can't see the grapple tines from the tractor seat. Result is usually a big, ugly hole the width of my grapple, or wider.
The cylinder movement is fairly slow -- no need for flow control on this gadget! I was doing most of this work at idle speed. It would close faster if I revved up the engine speed.
I have not owned a tree shear. However, I have a stump grinder like you.
   / Tree Puller: Pleased with my new Attachment #19
____________________
_------------------------QUOTE]
What is the RPM at idle?
I know it develops full pressure at idle, but you don't want to use it on an engine that idles at 750. :thumbdown:
Our Toolcat idles at 1250 and sometimes I forget to move the throttle lever up when working it hard.
   / Tree Puller: Pleased with my new Attachment #20
Hmmm. I don't know how far the jaws open, but if you could replace one of them with a wedge, you'd have a splitter, too!
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
