Tree recommendations
   / Tree recommendations #11
How wide of an area do you have where you want the screen? There are several different ways to handle this; plant type of thick evergreen and allow the lower limbs room to thrive, plant some thick foliage taller trees with some asthetic bushes below etc. In the last 15 years or so, I've planted around 30,000 trees myself on properties that I own. This last spring I planted 5100 trees. But, it was my worst planting. We had a severe draught and I lost about 95% of everything I planted. /forums/images/graemlins/mad.gif So, I'm sticking with fall planting unless the amount planted is small enough to be able to water. Besides the monitary loss, do you know how much physical labor and time I spent planting 5100 trees?! I certainly may not be the brightest guy, but with lots of practice and numerous visits from our state forestry service, I'm learning. /forums/images/graemlins/crazy.gif
   / Tree recommendations #12
I planted some white pines over the last two years. First year, $100 worth of 2'(35 trees). That winter the deer just about did them in. Second year, $100 of 4-5' trees, (ten trees).
The deer still had a go at them but came back like I had trimed them. So in summary, go larger. Also, when buying ask for discounted ugly trees. Most customers want prety, well balanced trees that will look nice from day one.
good luck
   / Tree recommendations #13
I'll 3rd or 4th the Leyland Cypress Recommendation. They are hardy, fast growers, prunable, deer resistant.
I planted 100 or so 3-6 inchers two years ago and some of them are now close to 10 feet tall! They are supposed to grow 4-6 feet a year. I have some that I bought locally that were 6 feet tall and fertilized and watered them heavily for the first year and they are now close to 20 feet tall.
They seem to like pruning in the July and you can even grow them fairly easily from the cuttings.
The most damage the deer have done to them is from rubbing their antlers against them and breaking them in half. I've just bent a lower branch up and held it in place for a few months and they are no worse for the wear (just a little shorter then their neighbors.
I've bought lots of trees from these guys and had good results: http://www.anythinggreen.com/
I've got some of their Thuja Green Giant Cedars and they have grown pretty fast too. I'm not sure how deer tolerant they are but will be finding out soon. I plant as much as possible in the fall or early spring. Your success rate is going to be much higher.
   / Tree recommendations #14
Boxwoods! They grow well in sunlight or shade..even well in "poor soil". You can trim them..or let them go and only "trim" the driveway side of them ( depending on how close they are) or just let them go period. Stay green all winter.
   / Tree recommendations #15
Rob,
I need privacy bushes too, and have done a lot of thinking on it. I decided on Japanese holly. (Ilex Japonica, I think)
They are evergreen, get 6-8 feet tall, and keep branches and leaves all the way to the ground. They grow real fast to 5 feet, then grow real slow after that.
They will never need trimming unless you want the look if a hedge.
I used to have 1 underneath my kids bedroom window. No kids could sneak in or out, and I wasn't worried about intruders. Their shiny leaves needles are the sharpest I have ever seen. Even the lightest touch gets you stuck. There are no barbs or anything, so no worries about that.
   / Tree recommendations #16
</font><font color="blue" class="small">( If you cut it down at 7 years and leave the stump, the tree will regrow to maturity again in 7 years.)</font>
JMHO, but that DOESN'T sound like something I'd want on my land. Some of those exotic things are OK but all too often they become a weed, and a nightmare to get rid of.
Has anyone tried to eradicate bamboo, which was the rage back in the '50's?
   / Tree recommendations #17
Ive got white pines growing in zone 5 here that are 35~50' tall and have branches all the way to the ground, so I planted some 2000 more along with 2000 sugar maples and 2000 white & blue spruce. the new plantings are all about same as far as die back, ~10% in 3 yrs, the whites are 2~4' high some deer damage last winter, the big pines lost most of the north side brannches due to the bad really really bad ice storm. the smaller spruces weren't yet above the weeds and only suffered some rodent damage... maples are hardly making it:(
Markm
   / Tree recommendations #18
I've had good luck with Norway Spruce at my place in Pennsylvania. I ordered my trees from Musser Forests and have been very happy.
   / Tree recommendations #19
Henry,
That is where I got my trees first time around. They do have quality products.
patrick
   / Tree recommendations #20
You may be thinking about a Paulownia tree which is marketed to Japan and which grows in both China and Japan. They're not suited for a privacy screen but they will readily resprout and can be coppiced.
Another idea for a privacy screen is to grow two or three offset rows of trees that are spaced far enough apart to allow for the trees to mature without crowding but also because of the multiple rows and offsets provides privacy long before the trees reach maturity.
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
2020 FREIGHTLINER M2 26FT STAKE BODY (A59575)
2020 FREIGHTLINER...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
1983 Ford 8000 Tandem Grain Truck (A59814)
1983 Ford 8000...
