tree removal - chaisaw problem, wrog fuel mix
   / tree removal - chaisaw problem, wrog fuel mix #41
Glad to hear. More then one recommended that...
   / tree removal - chaisaw problem, wrog fuel mix #42
Yup, gotta love that "congressional gas" ... Steve
   / tree removal - chaisaw problem, wrog fuel mix #43
Ok, i don't get this. I've had my saw since 92 with the same fuel hose. I probably just jinxed myself. Then there's the buddy of mine with a cheap one man auger and his fuel hose rotted right off into the fuel tank. I think it's the hoses that have change, for the cheaper, and that's one of the big problems we have to deal with. I think hygroscopic effects of the ethanol contribute to carburetor issues so i use fuel supplements to hopefully stave off those effects.
   / tree removal - chaisaw problem, wrog fuel mix #44
Speaking of sea foam and ethanol free gas.... If you ever smell sea foam, it has that distinctive alcohol smell to it. There are other petrol based products in it, but it smells mainly like isopropyl alcohol.
Are we wasting our money by buying ethanol free gas and then adding sea foam?
   / tree removal - chaisaw problem, wrog fuel mix #45
What is IPA?
http://seafoamsales.com/wp-content/uploads/2012/12/MSDS_seafoam_EN.pdf
Bruce
   / tree removal - chaisaw problem, wrog fuel mix #46
IPA is isopropyl alcohol.
Ethanol is also alcohol.
Are we trading out one evil for another?
   / tree removal - chaisaw problem, wrog fuel mix #47
Maybe trading one evil for another but sea foam has saved me a whole lot of carb overhauls over my "fixing" things years...carb overhaul in a can unless they are real bad..
   / tree removal - chaisaw problem, wrog fuel mix #48
I wonder if the two alcohols have different solvent and water absorption properties.
Bruce
   / tree removal - chaisaw problem, wrog fuel mix #49
Kinda like saying methanol and bourbon are both alcohol.....
My Stihl/Husky dealer tells me it doesn't matter if I burn 20:1 or 40:1, as long as its hi-test gas cause its got NO alcohol.
   / tree removal - chaisaw problem, wrog fuel mix #50
Did a little research. Ethanol is made from grains, and IPA is made from propane.
In theory, IPA should be much better on the rubber components versus ethanol.
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (A58214)
AM GENERAL M1123...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
Adams 6 Ton Fertilizer Spreader (A56435)
Adams 6 Ton...
