Trouble with a gould submersible pump (sump)
   / Trouble with a gould submersible pump (sump) #11
Is the bottom section of the pump plastic? I have to correct a statement I made earlier. All the ones I installed are working except the one I let the supply house talk me into that was plastic. The impeller was plastic and fell off after a short time.
Yes the bottom is plastic. I think the impeller is also. I am stuck between buying a new one at 330.00 or not getting one that is overkill for 150... I have a lot invested in my basement, so....... I have not done anything and it is still running..... but...:confused2:
   / Trouble with a gould submersible pump (sump) #13
You can get a 1/2 Hp or 3/4Hp with SST and Cast base at the big box stores with a lifetime warranty for about $180-200. thats what I did 10 yrs ago and have replaced it 1x already due to a bad float switch @ N/C. Then rebuild your existing one for a spare/backup unit.
With a lot of $ in the basement I wouldnt risk it. You could also put two pumps in with one float set higher in case the existing pump fails you have a built in backup. You need check valves in both then.
   / Trouble with a gould submersible pump (sump) #14
I am seeing more water powered backup systems lately. The fact that they don't need power has made them a choice that a lot of customers have liked. We have had several large storms that left us without power for many days.
   / Trouble with a gould submersible pump (sump) #15
Zoeller pumps are pretty good for the money . We get between 5 and 10 yrs out of them , and usually the only thing wrong when it quits working is the water finally rusts up the micro switch under the top cover .
   / Trouble with a gould submersible pump (sump) #16
If you get the Zoeller that has a float switch instead of the arm switch, you get a much longer life. The float can be changed and still use the original pump. You probably will need to go to a plumbing supply not a box store to get one.
With all the crazy stuff going on, i ordered another gould. I will repair the first pump and use as a backup. I also plan to have a water backup put in, but I need the time to get a good guy to do it!
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
CAT CS563 (A47477)
CAT CS563 (A47477)
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
