Truck mounted air compressor?
   / Truck mounted air compressor?
I use a inverter for my airless compressor in the van... works good for inflating tires and the compressor can be used with my underlayment senco stapler.
Bought all three in 1990 and still going strong... the 2000W inverter cost a fortune back then and I still use it for my sawzall, small sidewinder skill saw, etc.
I would think mounting the inverter inside the cab would be essential... West Marine has some inverters for boats...kind of pricey last I looked... still need to be protected.
What size compressor are you running off your inverter? I'm trying to find an inverter that I can possibly wire into my upfitter switch but don't know if it is a feasible idea yet. One of my switches is 30 amp.
   / Truck mounted air compressor? #32
It's a small Thomas mounted on an Emglow tank and regulator set up...
I do use it a lot.... mostly convenient to top up tires and similar... and in a pinch I have used it to staple underlayment and similar.
Had it since 1990... waited 5 year before taking the plunge and it's been worth it the last 25.
I bigger compressor would most likely overpower the inverter and it would shut down... Having the engine running also boosts the available voltage and the inverter likes that.
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
377811 (A48836)
377811 (A48836)
RIGID POWER DRIVE/HAND HELD THREADER (A53843)
RIGID POWER...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
