Truck size for gravel delivery?
   / Truck size for gravel delivery? #11
It’s worth mentioning, try to talk to people you know and get referrals for haulers they feel are trustworthy. There are a handful of crooks out there that will bill for more than they deliver. A lot of people have no idea what a ton of gravel looks like and can only assume the haulers are being honest.
   / Truck size for gravel delivery? #12
If you are buying the gravel by the ton then get a copy of the scale ticket/weigh bill. That will eliminate the crooks.
   / Truck size for gravel delivery? #13
First thing to know is how far the nearest pit is from you. That is the real determining thing. If its a few miles away you are ok and if it's 25 you are skrewed. Most of these guys bill by the mile. The best way to get a bargain is find the small timer that everybody else uses. Bear in mind though that the guy with the bigger dump like a triaxle will often be the better deal just by him hauling more per trip. Stone itself is dirt inexpensive around $10/ ton. All the rest is hauling and they really stik it to ya. Last time I got some was $400/ triaxle , around 22 tons. That amount won't quite fit in a tea kup but when you begin spreading it you may begin to think it will:confused3:
   / Truck size for gravel delivery? #14
Depends what you have access for in your location. Even something like a side dump or belly might be an option.
You can likely call the quarry and have them handle delivery or simply find a local trucker who can handle the delivery for you. Just depends on the quarry.
   / Truck size for gravel delivery? #15
Yep, gotta call around in your area.
In my area, an independent trucking company that deals with the quarry, has better rates than calling the quarry and having one of their drives deliver. //
We had to do the driveway in NH: 675'. The local contractor was very cheap, hauling it from a local quarry, cheaper and he spread it.
   / Truck size for gravel delivery? #16
I need to get several large truck/trailer loads of gravel soon for my driveway/parking area. Could someone point me in the direction as to the sizes of loads for each dump truck or trailer dump? Im sure I NEED THE "CRUSHER" run style of rock. l need to know soon for later this week. If you could give me a loose price so I would have some idea of what I'm doing. I don't mind paying for delivery. Just eliminating the overcharge type individual. I really appreciate any info on this. :thumbsup:
After delivery, I can spread it with the Kubota.
I've been involved in these discussions before. I surprisingly learned the terminology and cost of gravel varies tremendously, even in the same State. Unless your neighbor down the road posts a reply I'm afraid you aren't going to learn much in terms of cost and/or type material to ask for.
I suggest you call the nearest Quarry. They'll have local trucks that they call for deliveries. If you express your uncertainty and tell them exactly where you are they might even give you the Cell Number of a local trucker to contact. He could then guide you as to what type of material. He would also probably suggest that he bring you a load and then you and him can decide how much more you need.
   / Truck size for gravel delivery? #17
Typical truck/transfer (truck with trailer) is ten yards in the truck and another ten yards in the transfer trailer. Around here the price for twenty yards (one trip) is around $525 for road base. For your purposes, I would see if they carry road base. Standard gravel squishes out to the sides of the road whereas road base has fines mixed in with the larger rocks and creates a well-packed surface after it gets watered down.
This is the right answer, having been a "rock bucket" owner for long enough to put in my driveway and do a few other things. "Finds" are defined as parts, in the rock industry and also manufacturing. Used to be called a parts list with part numbers.....now it's Find list with Find numbers. In getting crushed rock of the right kind for a driveway, you have hard rocks that didn't get crushed all the way down to the powder which when watered and packed as troutsqueezer said makes for a good, hard bed that will retain it's shape and the hard rocks will support the load.
If you get something like crushed granite or river rock it will move around on you without something to hold it. One option with that is to lay down a bed of soft rock and get it good and packed and then come back with either of these or something similar for a good road after the rock has had time to get packed in the base. I did this for my drive as I wanted a brown driveway and the brown rock comes from the Red River and is river pebbles. Around here are quarries of a soft white caliche' that is your bed rock.
Obviously different rocks cost different amounts so look around and ask questions. Be careful about buying "washed" materials. Adds a lot to the cost and depending on your use, you may want the cheaper dirty material. Case in point is washed sand which is used for making concrete. Unwashed sand is a lot cheaper and is what you use for yard work and such. I can get my river rock unwashed and that gives me some river dirt/clay/sand (finds) to help in holding it in place. First time it rains on it it will wash the top of the rock for you making it look pretty.
Again you can get it by the load or the ton. The pit loads by the ton. The driver wants to sell by the load. By the ton you get what you pay for. By the load you get what the driver wants you to have for the price.....now how do you suppose I know that?
If you buy by the ton, tell the driver/supplier that you want x tons of y rock from z pit. Ask him for his hauling fee. Now you have your cost per ton. A cubic yard is approximately 3600# (as I recall....varies depending on what it is) so that will get you in the ball park cost for the material part for so much volume of whatever you choose for rock.
You can find the local pits easily by following a rock truck to the pit, if somebody doesn't know or they are not listed where you can find them....yellow pages, weekly neighborhood rag sheet, etc. If you visit there you can find out what they have and what they want for it.....the hauler will get a tonnage load ticket and you know the price per ton so that plus his fee for delivery is your price. If you don't want to go to all that trouble it could be several hundred bucks out of your pocket that you wouldn't have had to spend had you done your home work for a given amount of a given rock. Don't forget to factor in the spreading of that rock, however you choose to manage that.
Here we too have 10 yd/10 yd if using a bobtail 10 wheel tandem axle dump (usually built with a 14 yard dump bucket) and a 10 yard tandem axle "pup" (the little trailer they pull behind). These rigs are best for getting in small places with a good sized load.
Otherwise are belly dumps for making roads (but the other types of buckets make roads too, just don't lay material down in a strip quite like a belly dump), and end dumps where the trailer carries all the material and may be 40' long, carrying 25 tons legally.
Truck-pups and end dumps can chain the tail gate whereby only a certain amount of material will come out at a time and by them driving down your driveway as they raise the trailer/bed you can get a reall good spreading. If the guy knows his business a chained gate does a better job of spreading than a belly dump.....makes smoothing it out a walk in the park.
Just remember that it costs the operator basically the same regardless of the tonnage....slight wear and moderate fuel differences only. So get the biggest truck that you can get in your place for the best price.
Also, if you don't know the driver or have references, ask to see the load ticket from the pit before you pay. It has the tonnage that the quarry put on the truck. If the driver refuses, go elsewhere.
Want more, ask,
Mark
   / Truck size for gravel delivery? #18
The "small timers" around here are more expensive by alot.
When I first started the life of house ownership about 10 years ago, I had a good friend that owned a full sized dump truck capable of hauling 22 tons or so. He was who I called for stone figuring he'd treat me right.
He gave me the number of who he has haul for him and told me "he can deliver it cheaper than I can get it at the quarry for".
I trusted what he was saying but never understood. I only got a load every few years. And always used the guy he refereed me to. Well last year when building the building I knew I would be using lots of stone. (ended up being about 10 loads last year), so I figured it was worth calling around.
So I called the guy I had been using, and price was ~$16/ton. All the quarries in the area are owned by national lime and stone. So I called them to see how much "their" drivers can deliver for. I was shocked when I was quoted $22/ton for the same stuff I can get an independent (but large outfit) driver deliver for.
So I inquired about some pricing and how much I would pay if I owned a dump truck and came in and picked it up. Well....I'd have to pay $$18/ton to get it myself. So even if I owned a truck, using my equipment and fuel, it would cost me more than having it delivered. My friend was spot on when he told me this many years ago. So I asked why "_____ trucking" is delivering it for less than I can pick it up for. Well....volume and commercial account with the quarry. If "I" were to set up a commercial account, I could get for $13/ton. But that is still more than the trucking company I use has to pay for it I am sure. There is no way they are making money on a 70 mile round trip charging only $3/ton. But this trucking company hauls about 1000 tons a month in the busy season out if this quarry. So I am sure "their" commercial account" gets a better deal than little ole me if I had a commercial account there and hauled a few loads a year.
Point still remains the same....call around.
   / Truck size for gravel delivery? #19
In Oct I bought 120 yds of what we call 3/4 crushed dense pack, which is small crushed stones with a cement like powder mixed in, in 20 yd loads. Around here most buy by the yd and not by the ton. What the truck and load weigh, I have no idea.
It was $30/yd delivered. The truck came about 15 miles from where he picked it up.
The driver said it's what is usually put under asphalt as a base. The 20 yd loads came in a large 10 wheeler. I used it on my driveway.
It packs down really well and almost looks like asphalt when compacted and wet down.
   / Truck size for gravel delivery? #20
Something to consider is where you're needing the material dumped. Do you now have trees, landscaping, etc that will limit how high he can dump his bed? Can he maneuver a bigger truck off of main road to drive?
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55314)
2021 Unverferth...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
