TSC three point splitter
/ TSC three point splitter #1
YesDeere
Veteran Member
Merland
Getting the Speeco splitter tommotow from TSC, have a 790 Deere with 7 backhoe. Will my line for the hoe work on this splitter? What else will I need? Thanks for any help. JK
/ TSC three point splitter #2
I've been looking at the same splitter, it seems it comes with everything necessary to hook to the power beyond, tho I'm not sure if I have the hydraulic capacity to use it effectively with the 2305.
/ TSC three point splitter #3
Yes, that will work fine. Just make sure the splitter is hooked up BEFORE you start the tractor.
/ TSC three point splitter #4
It will be VERY slow on your 2305;)
Got it all hooked up and am very happy. Made some lines with quick connects and it works fine. Thanks
/ TSC three point splitter #6
Do not forget to top of your Hydros when you first hook up the splitter. That 4" cylinder will hold a gallon or more fluid. Top it off with the tractor running and the ram retracted. If you top it off with the ram out when you retract it it will over flow the sump and make a mess due to it taking less fluid on the retract side because of the piston rod taking up space. Don't ask me how I know.:eek:
Chris
/ TSC three point splitter #7
I looked at one of the three point splitters at my local TSC, thought it was pretty nice (but, unfortunately, already sold to someone else!). I already have a stand-alone splitter for the bulk of my splitting, but since my stockpile (and therefore my splitter) is at my in-laws...... i'd really like to have the Speeco/TSC three point splitter to use at home. They send us coupons every now and then, so it could be very affordable. I hope to buy one some time in 09 ! Hope you have good luck with yours.:)
/ TSC three point splitter #8
Check out the new Power Horse 3Pt. splitter from Northern Tool. It splits on on both cycles foward and back. It seems like this should save a lot of time since it doesn't have to recycle.
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2013 John Deere 2623VT Vertical Tillage Tool (A63116)
2013 John Deere...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A62131)
UNUSED RAYSKY...
