TuffTorq K46 Repair Guide with Pictures
   / TuffTorq K46 Repair Guide with Pictures #141
I thought I would just mention how I got my Scotts 2554 working again. I believe it is the K66 transmission. Three years ago the tranny went out. I changed the belt and fluid (turns out the fluid needs changing on a periodic basis - not that the owner manual ever said this) with no change. A new transmission from JD $1700 w/o installation. In my efforts to come up with an alternative, I came across a guy who rebuilds these for $400. But instead of a new cylinder/piston?, he has the original milled down. New oil and filter and whatever he else he needed, the tractor ran better than when it was new. I was impressed with the fix.
   / TuffTorq K46 Repair Guide with Pictures #142
I replaced these items as described on the first page of this thread AND got the 5W-50 oil.
1. Cylinder block (pump) kit
2. Cylinder block (Motor) Kit
3. Filter 105
I rebuilt mine and upgraded with k57 recommendations from Duane. I had wondered if I could have gotten by cheaper with just the parts you did. Quite a few people have posted that those are the only parts they did. My theory was that if I was going to do the rebuild it was going to be better than before, so I went with all the parts, about $400 worth. Costs even more now I heard.
My center case also was worn, not just the pump and motor. Seems to me the machined surfaces of pump/motor and case wear together. Center case is aluminum, pump/motor are steel. The machined surfaces are what I was told by tuff torq that go bad. Why would the steel wear and not the aluminum? I don't know why people are replacing pump and motor without replacing center case. Am I not understanding something right?
I am very happy so far with the result, hope it lasts. I have mowed 20+ acres so far this summer since the rebuild.
   / TuffTorq K46 Repair Guide with Pictures #143
golfhacker said:
I installed the motor, motor thrust bearing and pump over the weekend and it is pulling the hill alot better (would not pull up hill at all after half hour use) but I think it could be better so I ordered the center case kit and pump thrust bearings and will install in a couple of weeks.
I will post and let you know how the additional parts help. If nothing else I am becoming a pro at removing and reinstalling the tranny..LOL
Ok just got done adding the new center block and thrust bearings and now it works like new. I think if all I did was mow this transmission would be fine but I push snow in the winter and I think that must be a killer for this tranny.
   / TuffTorq K46 Repair Guide with Pictures #144
lightningrod said:
Hello Again! I did a rebuild last year in April. I got thru the whole summer mowing my acre and a half of hilly yard and plowed my 600 ft driveway all winter.
I don't think putting another K46 in is the answer. Maybe upgrade to better tranny for snow removal.
   / TuffTorq K46 Repair Guide with Pictures #145
I too upgraded from the K46 to the K57 spec's in my L120 Deere as I will be blowing snow this winter also...Just buttoned it up last night and started beating on it immediately....It's going up hill's that it never did before and is very quiet....Duane and Derrick have gone beyond most in regards to customer service....Good people...Many thanks for posting this thread in the first place !:thumbsup: Now if I can figure out a way to circulate the oil through a oil cooler through the drain ports I just put in...
   / TuffTorq K46 Repair Guide with Pictures #146
This year So far Ive mowed a few times and guess what. The transmission is heating up and Im loosing power again. The transmission lasted over 6 years from new and then the rebuild lasted only a year.
Im hoping for anybody's suggestions on what I may have done wrong. Im considering just getting a new K46 since I see them on eBay for $525.
Anybody's input is appreciated!!
It might not hurt to contact either Duane or Derrick @ tuff torq and run it by them and see what they have to say....If it ran fine up until this point with no issues or noise then I am at a loss as to what the reasons are for the drop in performance....
   / TuffTorq K46 Repair Guide with Pictures #147
Could you post a parts list for your k57 upgrade?
   / TuffTorq K46 Repair Guide with Pictures #148
Any chance of pics of the drain ports and location, or is it part of the K57 upgrade?
   / TuffTorq K46 Repair Guide with Pictures #149
Parts Required to Convert K46 to K57 This lists out as a K57A (Simplicity spec'd) hydrostat...This was the current pricing also....It's not cheap, but you have alternatives...
Item #/ Part Number on diagram / Quantity / Part Number Description/ Cost
1. 1 1 1A646088840 Pump Shaft (K57A) 25.47
2. 100 1 187Q0026010 Charge Pump Case Kit 8.35
3. 102 1 1A646088350 Inner Rotor 4.61
4. 101 1 1A646088360 Outer Rotor 4.82
5. 103 2 22351030018 Roll Pin 3.0 x 18 0.21 @
6. 97 1 1A646088450 Charge Spring 2.68
7. 96 1 1A646088410 Pin 2.5 x 9.8 0.34
8. 83 2 1A646025300 Spline Collar 1.34 @
9. 26 1 1A646088211 Filter 8.64
10. 87 1 19215489090 Snap Ring 0.26
11. 37 1 187K0099750 Motor Thrust Bearing 28.08
12. 201 1 1A646099530 K57R Repair Kit 373.81
13. 47 1 1A646029010 Magnet Holder 1.83
14. 8 2 19216324360 Magnet 2.94 @
15. 2 1115 1 liter 5w50 Synthetic Motor Oil 8.29 @
16. optional (104) 1 1A646099630 Thrust Bearing/Swash Plate Kit 37.12
Total $484.45 plus shipping
   / TuffTorq K46 Repair Guide with Pictures #150
IF YOU WANT TO ADD A DRAIN HOLE TO THE BOTTOM OF THE K46 CASE
SEE BELOW
Part Number
1. Add the (2) ports yourself by drilling & taping holes through the bosses provided in the lower case. (See ATTACH #1)
2. Order and install the following model K46 service parts w/8 mm drain bolts.
1 pc. 1A646084163 Lower Case (includes drain ports) IF YOU DON'T WANT TO DRILL AND TAP YOUR OLD CASE
2 pc. 187Q0399940 Drain Bolt Kit (includes seal washer)
Location A = Drains oil from Hydrostatic compartment.
Location B = Drains oil from Gear Compartment
1840 (A51248)
1840 (A51248)
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55314)
2023 Unverferth...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
CAT 416B (A47477)
CAT 416B (A47477)
