TuffTorq K46 Repair Guide with Pictures
   / TuffTorq K46 Repair Guide with Pictures #151
I can't quite figure out how to paste the picture from Word.....I can give the general location though....If you are looking a the hydrostat base cover...The large gear portion of the casting should be to the left........The drain can be drilled and tapped in the flat/boss area just below the gear portion of the casting.....
The location for the hydrostat drain is on the flat/boss just to the right of the round part of the casting closest to the outer part of the casting...Hope that helps...
   / TuffTorq K46 Repair Guide with Pictures #153
Thanks for the pic just what I was looking for.
   / TuffTorq K46 Repair Guide with Pictures #154
First off I want to Thank LotsofGreenGrass for this very informative post. Also thanks to GixxersRevolt for the videos. Very helpful! :drink:
I started to notice the lack of torque and power loss this spring when pulling my dethatcher. I have a 2007 LA140 with a K46BE with 1243 hours and have about 2-2.5 acres of hilly yard. Also have a steep 400 ft driveway I have to go up and down to get to my lower level lawns. I have mowed about four times this year and the last couple of times I wasn稚 sure if I would make it back up the driveway.
I have read a lot on this forum in the past, but found this post by a Google search.
I talked to a few people about my issue and some said it was the belt. Took a trip to my local JD dealer and got a new belt. I asked him if they ever had any problems with loss of power. He told me they do and that the transaxle is a 渡on serviceable part and I would need to replace it. So I tried the new belt first and had half the tractor apart to get it out. I ended up dropping the transaxle out in doing so. Since it was out I washed it and drained the oil. Refilled with the 5w50 synthetic. It took one quart. And once back together it did not perform any better.
I ordered the pump kit, motor kit & filter from Tuff Torq and had in four days. Pulled the transaxle out and drained it not really paying any attention to how much came out. Removed the cover and replaced the new parts with only one problem.
I got everything back together and was all excited to give it a try. Well that's when my problems started. It did nothing!! :mad::mad: I tried bleeding it as per Tuff Torq instruction and still nothing. Took it back out and pulled it apart to see what was wrong. I found that I forgot to put the small washer (#39) in when replacing the motor. I did find that with out the washer the bypass would not function. I got it all back together and back in and it still did not work! Back out for the third time. Did some more reading and found that it calls for 2.3 liters of oil or about 2 quarts. That was my problem from the beginning! When I had the trans out to replace the belt I drained about a quart out thru the top vent, so I just assumed that that's what it would take to fill. Once I got everything ready for what I hoped to be the last time before replacing the cover I filled the case just up to where it seals to the case. It took 2 quarts and I new that was hopefully my problem. After replacing the cover I added about a 1/2 quart.
Looking at how the differential area and the motor/pump side are almost two separate sections I believe that the first time after installing the new parts and filling from the vent that the oil filled only the differential side and did not get much at all into the motor/pump side. It looked to me that the gear side would have to fill up to be able to flow over into the pump/motor side. The one quart didn't do that. Looking in the vent hole it appeared to be full. But it was only the gear side.
All back in and this time it moved!! Growled a bit a first then quieted down after driving it forwards and backwards for a bit. Plenty of torque and power now. When going down my driveway for a test run I realized how bad it was before. Now if I let of the pedal too quick the rear tires will skid like when it was new. Test run was a success and had a big grin when I could just cruise back up the driveway.:)
   / TuffTorq K46 Repair Guide with Pictures #155
@ LotsofGreenGrass...Thanks for the heads up on this transmission. I opened a small engine shop with a friend and wasn't sure if I wanted to tackle ripping into this K46V without researching first. Not only was your post informative but funny as ****. I know the frustrations of parts popping back out and "Jesus" clip type parts. Now I can give my customer a good idea of what to expect in the price range of both repair VS replacement.
   / TuffTorq K46 Repair Guide with Pictures #156
Re: TuffTorq K46 / John Deere L110 Transmission Repair Guide with Pictures
Thanks for your info on the john deere L110 K46 hyro.
After reading your post, and watching the video on You Tube (k46 Rebuild parts 1 & 2), I was able to rebuild the K46. It works great now. The bleeding or "Air Purging" took about 20 minutes before it regained its strength. From start to finish it took about an hour to rebuild. replaced pump block & motor block parts and some other odds and ends.
   / TuffTorq K46 Repair Guide with Pictures #157
Hello, all!
What an awesome thread! Excellent work by everyone who took the time to learn and post. Awesome.
I'd like everyone's take on a slightly different but related matter concerning the K46. I'm about to take delivery of a Husqvarna 24V42LS with a K46 and Hilliard auto-locking diff. From the perspective of present owners, and especially those of you who've actually dug into and revived damaged K46s, what should I, as a new owner, do to prolong the life of my new transaxle?
For example, was anyone able to pin down specifically the failure mode? IOW, what started the cascade of damage that led to your failed transaxle? How would you avoid that problem in the future, if you could?
A complication I see here is the 3-year warranty from Husq. Do I tempt fate and go with the "lifetime oil" (ha ha) proposition, or do I do the smart thing and drain it after 10 hours and refill with good quality synthetic 5W50, at the risk of voiding the warranty? As I see it, NOT changing the oil at 10 or 20 hours and then every 100 hours is a bad idea, but if it's going to void the warranty then....? So if I DON'T change the oil, have I set the transaxle up for a failure soon after the warranty expires?
The first thing I'm going to do when it drops onto my driveway is crawl underneath and look for the drain bolts. Maybe they've seen the error of their ways and have included them on recent production. (ha ha)
What would you guys do?
lightningrod said:
Hello Again! I did a rebuild last year in April. I got thru the whole summer mowing my acre and a half of hilly yard and plowed my 600 ft driveway all winter.
I don't think putting another K46 in is the answer. Maybe upgrade to better tranny for snow removal.
I think this would be wise, or upgrade to a larger tractor.
Hello, all!
Change to recommended synthetic oil at shorter intervals. Run it until it dies.
If I had to do it again, I would neodymium magnets to the case to trap more metal and do the upgrade. Metal is the main issue.
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
2016 Crae Garbage Truck (A51692)
2016 Crae Garbage...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
