Turbo Charger Upgrade for Older Kubota
   / Turbo Charger Upgrade for Older Kubota #31
The compressors pressure map is certified for sea level at ambient temp and barometic air pressure by the OEM manufacturer.
Typically, OEMs derate their turbocharger compressors @ altitudes > 5,000 feet due to the major decrease in air pressure, this will constrict both the choke and the surge regions of the compressor map significantly, which, if not accounted for, will allow for gross overspeed, gross overheating, and supersonic air waves inside the compressor leading to its self destruction (aluminum compressor wheels also cannot handle heat much greater than around 325*F, titanium wheels are made especially for high altitude high temp operations).
Be SURE to tell the turbo folks that you plan on operating at 10,000 foot elevations so that they can take this extreme altitude into consideration when they recommend the A/R ratio of the air compressor housing and the compressor wheel for your turbo application to keep it within their specified limits of operability.
What works at sea level does not work at two miles high! /forums/images/graemlins/wink.gif
   / Turbo Charger Upgrade for Older Kubota #32
Rocketman,
It also isn't a bad idea to use an intercooler to cool the turbo compressed air prior to it entering the combustion chamber, as the boost effects will be maximized, as density is inversly proportional to temperature. This cooling also helps to decrease NOX emissions and increases efficiency.
Steve
2017 Nissan Frontier Pickup Truck (A55788)
2017 Nissan...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55302)
PENDING SELLER...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Bobcat 72" Skidloader Bucket Broom (A50775)
Bobcat 72"...
CFG Industrial MX15RX (A53316)
CFG Industrial...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
