Turbos and Yanmars
   / Turbos and Yanmars #21
Well, normally thats the idle limit spring that controls hunting from the governor, normally you don't want to mess with that but I don't know what series engine you are screwing with.
   / Turbos and Yanmars #23
talked with a guy today. He said you don't want to put to much p.s.i. to a diesel engine that isn't turbo already? something about oiling the bottom of the piston skirt? also said 5-8 p.s.i. is not worth the trouble.
Well its been several years now and the turbo is still working very well. Still boosts to about 5 psi and all is good.
As to not being worth trouble, I have to disagree. At my elevation 7500 ft or so the tractor smoked due to being rich and was down 20% on power. Now it does not smoke as bad and is up on power. So if you ask me, someone who went thru the trouble I say its worth it.
   / Turbos and Yanmars #25
It sounds like using a turbo to bring intake pressure back up to sea-level values is very worthwhile.
   / Turbos and Yanmars #27
I have dreamed of adding a turbo to my yanmar powered jd3005 since I bought it. Has the 3tnv82a engine, and does an adequate job... but I'm of the belief that any diesel engine can benefit from a turbo and still be reliable, if boost levels are kept reasonable. I've turbo'd a NA 6.2l chevy truck, woke that right up!
I don't expect 40hp out of my 27hp motor, but 32-34hp would be a reasonable expectation.
   / Turbos and Yanmars #28
Here's another option for small engine turbos, this is an OEM turbo for the modern tier 4 common rail TATA 800cc 2 cylinder 4000 RPM diesel made in India. Probably a little big for a sub 800cc engine under 3000 RPM. Would be easier to fab for 2 cylinder units. NOT a twin scroll, just has the exhaust manifold cast with the turbine housing bolts diectly onto head in OEM application.
Ignore the gasoline engine recommended size.
789997-1 - Journal Bearing Turbos - Applications - TurboMaster
   / Turbos and Yanmars #29
I added a turbo to my 3 cylinder 90ci Ford 1720 tractor 3 or 4 years ago for a significant power gain and will say its the best thing I’ve ever done. It turned a good tractor into a great tractor!!
I have put several hundred hours on it with no problems.
I used a Garrett GT1752 waste gated turbo off a Saab. Bought the turbo at a swap meet for $35.
I have photos in the review section.
Definitely worth it.
90cummins
Electric Sweeper W/Pressure Washer, Water Hose, & Mister (New/Unused) (A59225)
Electric Sweeper...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
5' PULVERIZER, 3PT (A52708)
5' PULVERIZER, 3PT...
2024 Load Trailer (A56859)
2024 Load Trailer...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
