Turf tires on front with ag rears?
   / Turf tires on front with ag rears? #11
As long as he could get them in the same circumference, yes, but from what I've seen they are not usually available in exact sizes. If it was really close, the lead or lag may not be a problem.
Of course, new wheels would be needed as well as the IND tires are going to be wider than the Ags.
John
   / Turf tires on front with ag rears? #12
John
   / Turf tires on front with ag rears? #13
If you have a 4wd tractor, you will run into the binding problem. Rarely can you find turfs that would match the diameter of the ags.
You can promise to keep it in 2wd when the turfs are on. That's your call - folks tend to forget tho, human nature. Over time, when in 4wd, you will greatly increase the wear on the $$$ drivetrain.
--->Paul
   / Turf tires on front with ag rears? #14
--->Paul
   / Turf tires on front with ag rears? #15
I tore up my front u-joint. I could only afford back tires, then front tires later. I had turfs, and wanted R4. So, I went through the goodyear and Firestone charts, and thought I had a good match. It was close, but not close enough.
I put in a new u-joint, and finally got the right size R4 up front; everything has been fine since.
Mine is a mid 80's Kubota B8200(granddaddy to the B2710) with FEL, as well as a scraper or rotary mower.
   / Turf tires on front with ag rears? #16
   / Turf tires on front with ag rears? #17
I DO I DO!!!
Only a 2wd though. the fronts will still leave something if you are moving fast, but I don't know how they compare to the 4 rib ags, these are all I have. Only about 10 minutes to change the rears with an inpact.
If they are a different size you will do zero damage if you keep it in 2wd. In 2wd the shafts freewheel. In 4wd you may have a problem.
   / Turf tires on front with ag rears? #18
I DO I DO!!!
   / Turf tires on front with ag rears? #19
</font><font color="blue" class="small">( I have a Bx23 with ag tires front and rear. <font color="red"> I remove the fel and bh to mow, but I'm finding that I am tearing up the lawn wherever I have to make sharp turns. </font> It seems that it is the front tires that are doing the damage so I'm wondering if I should just change the fronts to turf tires and leave the rears as is? Anybody done this? Any disadvantage other than not as much traction with the fel?
Thanks,
Jim )</font>
<font color="red"> I've never found this to be a problem with my bx 23 with ag tires.I always mow with the FEL & BH attached as i've never had either of them off the tractor.
</font>
   / Turf tires on front with ag rears? #20
Thanks,
Jim )</font>
</font>
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
Doosan 25 Forklift (A54865)
Doosan 25 Forklift...
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
Club Car Utility Cart (A55853)
Club Car Utility...
2015 Ford Transit 250 Cargo Van (A55852)
2015 Ford Transit...
