Turn the key and only get a click sound, 2210D
   / Turn the key and only get a click sound, 2210D #11
I had a 276D that did the same thing for months. I troubleshot every inch of of the ignition circuitry without finding anything wrong. Sometimes click, sometimes instant start. Finally out of frustration I called a dealer. He said, "Oh yeah!, there was a design change. That originally came without an ignition relay. We have a relay retrofit kit that will solve the problem." It did, that was years ago.
Without the relay the full solenoid current was going thru the key switch which really wasn't designed to hande that much current, so the key contacts were burning causing an intermittent bad connection. With an ohmmeter they checked fine but would add just enough resistance under load to not allow the solenoid current to go to full potential.
With the retrofit now the key only turns on the relay and the relay handles all the solenoid current.
Not sure if this will apply to your problem but I would check to see if there is an ignition switch relay.
   / Turn the key and only get a click sound, 2210D #12
A good test for battery and loose/corroded terminals is for someone to stand in front of the tractor, turn your lights on, turn the starter key. IF the lights stay bright without dimming, you have other problems, ie solenoid etc. IF the lights go out, check battery leads then if cleaning/tightening doesn't do the trick, check the battery or other heavy duty terminals.
Wash your battery terminals with boiling water about every 100 hours, use vaseline on the terminals or one of the proprietary products available on the market.
Your battery is like every other part of your tractor, it needs maintenance.
Thanks guys. It was indeed a bad connection on the solenoid.
Cleaned it, tightened it up and now I'm golden.
Thanks, Keith Zack
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A49346)
2020 John Deere...
2012 Mercedes-Benz C250 Sedan (A48082)
2012 Mercedes-Benz...
John Deere 2155 Tractor (A48837)
John Deere 2155...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2003 Land Pride 4x4 Utility Cart (A49346)
2003 Land Pride...
12ft Stainless Steel Livestock Panel (A48837)
12ft Stainless...
