Turning Drought to Advantage: Dam Rebuilding?
   / Turning Drought to Advantage: Dam Rebuilding?
Sounds like an interesting siphon system. Also sounds a little more complicated than what I need, but I could be wrong. How big is the reservoir you are speaking of? That might help determine the pipe size that I should consider.
I like the idea of removing water from the bottom of the pond.
Also, for clarification, I am looking for (the rare) overflow release only - there is no "flow" to my pond.
   / Turning Drought to Advantage: Dam Rebuilding? #12
Dobber, the pond that was dug out is fairly large. At its deepest its 25' deep and about 400' x 200'. What determines your outlet size is the watershed area. This particular pond had a fairly small watershed and got away with just a 18" drain. That may seem a bit large, but thats all it has. Most dams in our area require a safety or area where the flow will be allowed to go over a spillway in the event the usual drainage system cannot handle extreme flows or becomes blocked. This particular pond has a continual inflow, very slight but enough to always keep it full. It does not use a siphon system, just simply the head pressure of the water level to force the water from the bottom up to the drainage box. Its a little difficult to explain but really quite simple. If I get the chance, I'll shoot a few shots of the drain system to get the folks here a better idea. Rat...
42013 (A51691)
42013 (A51691)
CFG Industrial MH12RX (A53316)
CFG Industrial...
2019 Chevrolet Express 2500 Cargo Van (A55788)
2019 Chevrolet...
2016 Morbark Chipper (A55787)
2016 Morbark...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
