TURNPIKE TRAILOR TIRES
   / TURNPIKE TRAILOR TIRES #11
Taiwan ,china, Korean, etc, are there any really difference tire in quality ?? I know some will say yes ,but I imagine there are some specs all tires must meet to be sold for hwy use. Other than short tread life on some of the car/truck tires, never had a tire failure. For trailer tires For me it's a toss up. I've got the cheapest 235x85x16"s I could buy on my dump trailer and haven had a tire failure yet and that's hauling 6-7 tons a load. I usually end up replacing trailer tires long B-4 the tread is gone due to dry rot
   / TURNPIKE TRAILOR TIRES #12
Chris,
Are there still different versions of the Greenball, or is that info out of date as well?
There are. I only use the Tow Master Radials. I will not touch a bias anything.
Chris
   / TURNPIKE TRAILOR TIRES #13
I agree about replacing well before they Wear Out. A dump trailer for most is easy on tires due to short distances towed. Campers and boat trailers are usually the worst. People want to get there so they drive fast and it's usually a hour or more at a time. Heat is the enemy. Speed and inflation create it.
Chris
   / TURNPIKE TRAILOR TIRES #14
This thread could probably also use some comments on using the proper valve and rim if you get higher rated tires. If I remember correctly other threads pointed out that the E range tires (which I got) needed an air pressure which exceeded many of the lowly rubber valves.
   / TURNPIKE TRAILOR TIRES #15
That's correct. I use bolt in HP metal valve stems
EZ-GO Electric Cart (A55853)
EZ-GO Electric...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
Miles exempt on title Year: 1999 Make: Ford Model: F53 Vehicle Type: Recreational Vehicle Mileage: (A55853)
Miles exempt on...
2010 Chevrolet Express Shuttle Bus (A55852)
2010 Chevrolet...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2025 JMR Tree Boom Skid Steer Attachment (A55851)
2025 JMR Tree Boom...
