RobJ
Elite Member
rbargeron said:I should probably let it go, but I'll make one more point that counters the predictions of doom and gloom. There's a lot of design margin in low-rpm engines. As an example, tractor manufacturers are apt to offer a model with a normally aspirated engine rated at say 45 hp, and another model with the same basic engine and a turbo, rated 15% higher, and still another with an intercooler etc. rated even higher than that. They are all likely to use the same crank, pistons, transmission, etc. A small up-tick in power will not kill it. It might reduce its average rebuild life from 8,000 hours down to 7,500 - but if it accomplishes the objective its exactly the same economy as buying bigger. Adjustment of the fuel pump rack travel isn't always available - but it's one way to get a small increase in top end power.
What you say is true but when you add a turbo you also add more air to balance the extra fuel. A non turbo engine can run exhaust temps of 900 degrees, a turbo version can produce more power but still maintain exhaust temps of 900 degrees. Talk to the diesel truck guys that add the chips, most all..and they should..add an exhaust temp gauge. Pulling a trailer up a long grade with a 150+hp chip and you can melt a brand new PSD.
I've posted before that the same exact engine can be rated differently, continious duty, such as a generator set, water pump. And a intermitting duty rating, usually a truck, maybe a tractor. These know the load will be heavy but not on all the time. When I was a mechanic I replaced a v12 diesel in a very large crane that was designed and built in Europe(hills and such as terrain). They shipped it to the gulf coast, flat land, and burned up the motor between Houston and Beaumont. We installed a new engine, had the pump sent out and reset to a continious duty setting, and sent themon their way.
And never let it go!!
